Will an ITR LSD fit in a 2000 Si tranny?
Re: Will an ITR LSD fit in a 2000 Si tranny? (newspeedR)
yes it will fit and no you dont need a new speedo gear...
Edit: Ken just said that it does fit, but I need a new final drive. Can anyone confirm this?
[Modified by Ehron, 1:48 PM 12/5/2002]
Moderator
Re: Will an ITR LSD fit in a 2000 Si tranny? (Ehron)
type r LSD will fit....but you will need....the carriage bearings (then sealed bearings not the open bearings), and a type r big gear that goes over the lsd.....
yes you need the diff gear
U still might want to go with the ITR LSD and to an upgrade to the tranny....might be better then just getting the LSD.
Re: Will an ITR LSD fit in a 2000 Si tranny? (SpooN Man)
You need to use your original final drive diff gear from your Si tranny...
And as far as bearing go, you can use either a sealed Ball bearing or you can use a Roller taper bearing...
Re: Will an ITR LSD fit in a 2000 Si tranny? (Hooch at 8400-RPM)
Is the type R final drive better than the Si's? They are both 4.40 right? How is that an upgrade? Thanks.
The final drive ratios are the same they are 4.4 I believe. You will want to use the R bearings. They don't need to be shimmed like the other honda bearings.
fridexter
12-11-2004 12:35 PM
turboex
05-11-2004 05:31 PM
