WILL 95 GSR REAR SWAY FIT 93 DELSOL SI?
Re: WILL 95 GSR REAR SWAY FIT 93 DELSOL SI? (gan ni nia)
Yes it will fit. The del sol came with a rear bar that is bigger than the teg bar. The teg gets a 13mm and the sol gets a 15mm. You'll need to check to see if you have the holes for the sway bar to mount to the control arms. If you do, than all you'll need is the D brackets and end links. If you have a front sway bar, I'd go with the del sol sway bar. The best way to get it would be through an online honda parts place, like hparts.
Re: WILL 95 GSR REAR SWAY FIT 93 DELSOL SI? (f1-fan)
I've got a 93 Delsol Si. I think it comes stock with only a Front sway bar, but no rear. If i were to find one off a GSR, it would bolt right up?
yes just get all the parts..check if the control arms (LCAs) have holes to accept the bar..otherwise get the GSR or LS/RS as well...
front Si/EX (5gen) = 21mm
front GSR/ITR = 24mm (uses different endlinks, but just complete, bar and you be fine)
front LS/GS = 22mm
front LS/GS = 22mm
sol2nr
10
02-17-2004 06:29 PM
BLK JDM
01-23-2003 09:45 AM
