whats the smoke page
I forgot i knew these dam definitions about the smokes.
My car was smoking white smoke like a **** out of the exhaust.
what does that mean??
RIP ILL: 26Jan1945-02Feb2017 -&- JLVK: 14Jun1925-13Dec2016
Re: whats the smoke page (sshaikh01)
white smoke usually means coolant fluid is getting through from the head gasket.
sorry to break it to ya...
Re: whats the smoke page (ZylexSNL)
is it hard, i have to get the whole head off right ?
there will be differing opinions as to whether or not you can do it. some will say it's easy and others will tell you to take it to a shop. one thing i'll say is that it will not be cheap to take it to a shop.
good luck!
[Modified by ZylexSNL, 3:39 PM 7/15/2002]
i have done engine swaps, have swaps the suspensions on my own, and am capable of fixing minor things, but do not have the tools .
i guess i have it to take it to the shop..
one thing that i've heard (i've never cracked open a head myself) is that you must make sure that you line everything up properly, and make sure that the new gasket isn't upside down.
basically, if you have a helm's, it sounds like you should be able to do this yourself...
HTH,
- steve
Re: whats the smoke page (C5_ALLMOTOR)
Make sure you drive the car as little as possible in the meantime. The leaking fluid can cause your engine to run VERY hot and could possibly warp the head. I'm pretty sure you don't want to spring for a new head while you're at it. Make sure you keep the coolant filled to help the engine temps.
B96v6
B96v6
