What wrong with my gas pedal
Old 03-01-2003, 09:51 PM
sshaikh01's Avatar
Default What wrong with my gas pedal
The gas pedal is hard to press.
Once i use a bit of a force, i hear a cut, and its fine. But after i let it go to change
the gear, its the same way again.
Old 03-01-2003, 10:28 PM
Cuong-nutz's Avatar
Default Re: What wrong with my gas pedal (sshaikh01)
Dang, you're having all sorts of problems. Is this the Si or the EX? Oh well it doesn't matter. You check to see if the mat is in the way? Throttle cable snagging up on something?
Old 03-01-2003, 10:32 PM
sshaikh01's Avatar
Default Re: What wrong with my gas pedal (Cuong-nutz)
Its a 99 si.
There is no carpet in the car. The carpet was stolen.
Old 03-01-2003, 10:34 PM
bryan305's Avatar
maybe the throttle blade is actually sticking...try checking that manually, then work your way back one component at a time to the pedal; throttle blade, cable, pedal...whatever else touches it
Old 03-01-2003, 10:53 PM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
It sounds like something is getting caught somewhere, I would think it impossible to get a knot in the throttle cable, but it sounds as if you are stretching something out then it goes back to the position it was in before applying pressure to it.
Sorry to hear about everything that has been going wrong with your car, but was it insured? Cause you have been going through some problems as it seems, luckily some of them are the little annoying things and not major problems.
I was going to say the same thing, this member's problems have been the only ones on my mind the past few hours...I have my own problems.
Old 03-02-2003, 08:37 AM
yaya's Avatar
Default Re: What wrong with my gas pedal (SHAUNTS99)
TB has gunk in it
VietCloud7
05-06-2008 04:46 PM
joeg26er
02-19-2003 06:15 PM
95accordracer
01-11-2003 07:43 AM
Cat
09-30-2002 06:48 AM
sa21199
01-04-2002 03:25 PM
Quick Reply: What wrong with my gas pedal
