what kind of tranny u run on sohc turbo
as stated i just wanna knoe becuase i have the ex tranny and in first and second gear its all wheel spinn on the street just wanna knoe how the other trannies feel thats all
Re: what kind of tranny u run on sohc turbo (blackeg)
no i dont.......i knoe the jdm trannies have then though do u knoe how the gearin is on that trannie?
Re: what kind of tranny u run on sohc turbo (d15nonvtec)
the gearing in the rare and expensive jdm d15b tranny is exactly the same as the ex/si tranny. i'm considering one myself, but i can't find one for under $500, and even at that price it's difficult. plus you never know about the condition of it.
you don't want to run a cx / vx / dx / lx tranny; i bet you still won't have traction, you'll just be slow.
the first gears in all the trannys are the same. the second gear in the cx / vx / dx / lx trannies is slightly longer. i'm not sure if you could put that gear in there, but even if you could it would be pointless; you need traction in first gear, first.
your best bet is to get a quaife for your tranny, get a traction bar, do an equal length drive setup (i don't know much about this yet), solid motor mounts, and *learn how to modulate*.
Re: what kind of tranny u run on sohc turbo (OoHiTzToMMy)
Here's Mista Bone's webpage on D-series trannies. It might help you out somewhat. http://home.cinci.rr.com/mistab0ne/tranny.html
Re: (xerox445)
What about the ZC's that came in the older integ's.(like my friends '89) They are D series motors and they come with equal length driveshafts but I don't know about the gearing.
Re: what kind of tranny u run on sohc turbo (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">
the first gears in all the trannys are the same. the second gear in the cx / vx / dx / lx trannies is slightly longer. </TD></TR></TABLE>
I'm pretty sure that all of the first gears are NOT the same unless they have very different final drives.
EDIT: I have a dx tranny still and still have no traction in first or second gear. Either get the d15b tranny or throw a lsd in the tranny you have. y8 or d15b will always be the answer to a d series transmission question without building a hybrid.
Vice President/CEO
Re: what kind of tranny u run on sohc turbo (Daniel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel »</TD></TR><TR><TD CLASS="quote">Here's Mista Bone's webpage on D-series trannies. It might help you out somewhat. http://home.cinci.rr.com/mistab0ne/tranny.html</TD></TR></TABLE>
great source, good read..
I'm running a y8 tranny with a quaife and traction in first is ok. I am going to throw my polyurethane motor mounts in there and see what kind of difference that makes.
Re: (GTlvr82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 »</TD></TR><TR><TD CLASS="quote">What about the ZC's that came in the older integ's.(like my friends '89) They are D series motors and they come with equal length driveshafts but I don't know about the gearing.</TD></TR></TABLE>
I'm wondering about this too. Cause in Honda-Tuning's Budget Boost segment...they went with a ZC tranny...but never said why. Anyone know the gearing for a ZC tranny? Do all ZC trannies in the 1st gen integ have equal length driveshafts?
Re: what kind of tranny u run on sohc turbo (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">I'm pretty sure that all of the first gears are NOT the same unless they have very different final drives.</TD></TR></TABLE>
go look at mista bones tranny page... the finals are different, but the gears are exactly the same.
also, doesn't the avc-r boost controller let you change the amount of boost for each gear? someone told me it does, but i really don't know. if that is true, get it and turn the boost down in first gear.
EDIT: I have a dx tranny still and still have no traction in first or second gear. Either get the d15b tranny or throw a lsd in the tranny you have. y8 or d15b will always be the answer to a d series transmission question without building a hybrid.</TD></TR></TABLE>
1st gear on all d-series is the exact same, but they do have different final drives. I would do the following :
1) Stop trying to drag launch on the street.
2) Replace compliance bushing on front lcas.
3) Investigate an LSD.
4) Take a look at traction bars (www.jimfab.com)
Re: (94si94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx »</TD></TR><TR><TD CLASS="quote">Invest in traction bars, and good sticky tires. Otherwise your problem will not be solved.</TD></TR></TABLE>
Umm, i suggest an LSD, Z10 radius rods, an Ingalls engine dampener and a boost controller with scramble boost. These 4 items will solve your problems.
BTW, the 4.25/6 final drive and gearing of the y8 trans is perfect for boost, IMO
96-00 DX 2DR and 4DR had 4.06
96-00 CX/DX hatch had 3.72
Modified by 337 GTI 1.8t at 4:50 AM 12/27/2003
Multi-paradigm
Re: what kind of tranny u run on sohc turbo (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote">
Period.
Period.
egturbo
01-17-2003 01:18 PM
