what kind of tranny u run on sohc turbo
Old 12-20-2003, 11:07 PM
OoHiTzToMMy's Avatar
Default what kind of tranny u run on sohc turbo
as stated i just wanna knoe becuase i have the ex tranny and in first and second gear its all wheel spinn on the street just wanna knoe how the other trannies feel thats all
Old 12-20-2003, 11:13 PM
blackeg's Avatar
Default Re: what kind of tranny u run on sohc turbo (OoHiTzToMMy)
do you have a limited slip? it should help with some traction issues.
Old 12-20-2003, 11:14 PM
Default Re: what kind of tranny u run on sohc turbo (blackeg)
no i dont.......i knoe the jdm trannies have then though do u knoe how the gearin is on that trannie?
Old 12-20-2003, 11:17 PM
d15nonvtec's Avatar
on the d series the jdm trans with the limited slip only came on some of the d15b's, but good luck findin one
Old 12-21-2003, 12:18 AM
The Internet Tough Guy's Avatar
Default Re: what kind of tranny u run on sohc turbo (d15nonvtec)
the gearing in the rare and expensive jdm d15b tranny is exactly the same as the ex/si tranny. i'm considering one myself, but i can't find one for under $500, and even at that price it's difficult. plus you never know about the condition of it.
you don't want to run a cx / vx / dx / lx tranny; i bet you still won't have traction, you'll just be slow.
the first gears in all the trannys are the same. the second gear in the cx / vx / dx / lx trannies is slightly longer. i'm not sure if you could put that gear in there, but even if you could it would be pointless; you need traction in first gear, first.
your best bet is to get a quaife for your tranny, get a traction bar, do an equal length drive setup (i don't know much about this yet), solid motor mounts, and *learn how to modulate*.
Old 12-21-2003, 12:32 AM
Daniel's Avatar
Here's Mista Bone's webpage on D-series trannies. It might help you out somewhat. http://home.cinci.rr.com/mistab0ne/tranny.html
Old 12-21-2003, 12:57 AM
JDMlyfestyle's Avatar
Get a EX/SI tranny and throw in a Kaaz, Qaufie ect.
Old 12-21-2003, 07:17 AM
xerox445's Avatar
Default Re: (JDMlifestyle)
B Series Swap
You could get one of those Phantom Grip mah bobers, but i think they just break your Diff after a couple of weeks.
Old 12-21-2003, 07:23 AM
GTlvr82's Avatar
Default Re: (xerox445)
What about the ZC's that came in the older integ's.(like my friends '89) They are D series motors and they come with equal length driveshafts but I don't know about the gearing.
Old 12-21-2003, 07:25 AM
Ricey McRicerton's Avatar
Default Re: what kind of tranny u run on sohc turbo (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">
the first gears in all the trannys are the same. the second gear in the cx / vx / dx / lx trannies is slightly longer. </TD></TR></TABLE>
I'm pretty sure that all of the first gears are NOT the same unless they have very different final drives.
EDIT: I have a dx tranny still and still have no traction in first or second gear. Either get the d15b tranny or throw a lsd in the tranny you have. y8 or d15b will always be the answer to a d series transmission question without building a hybrid.
Old 12-21-2003, 07:29 AM
Vice President/CEO
kKdARIAN's Avatar
Default Re: what kind of tranny u run on sohc turbo (Daniel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel &raquo;</TD></TR><TR><TD CLASS="quote">Here's Mista Bone's webpage on D-series trannies. It might help you out somewhat. http://home.cinci.rr.com/mistab0ne/tranny.html</TD></TR></TABLE>
great source, good read..
Old 12-21-2003, 07:44 AM
Pfieff's Avatar
I'm running a y8 tranny with a quaife and traction in first is ok. I am going to throw my polyurethane motor mounts in there and see what kind of difference that makes.
Old 12-21-2003, 08:19 AM
could i use the shift forks in the new sohc trannies? i hear that they are made stonger then the 92-95 sohcs
Old 12-21-2003, 10:35 AM
Simple SOHC's Avatar
Default Re: (GTlvr82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 &raquo;</TD></TR><TR><TD CLASS="quote">What about the ZC's that came in the older integ's.(like my friends '89) They are D series motors and they come with equal length driveshafts but I don't know about the gearing.</TD></TR></TABLE>
I'm wondering about this too. Cause in Honda-Tuning's Budget Boost segment...they went with a ZC tranny...but never said why. Anyone know the gearing for a ZC tranny? Do all ZC trannies in the 1st gen integ have equal length driveshafts?
Old 12-21-2003, 10:52 AM
94si94cx's Avatar
Default Re: (H23 EG Hybrid)
Invest in traction bars, and good sticky tires. Otherwise your problem will not be solved.
Old 12-22-2003, 09:41 AM
Default Re: what kind of tranny u run on sohc turbo (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure that all of the first gears are NOT the same unless they have very different final drives.</TD></TR></TABLE>
go look at mista bones tranny page... the finals are different, but the gears are exactly the same.
also, doesn't the avc-r boost controller let you change the amount of boost for each gear? someone told me it does, but i really don't know. if that is true, get it and turn the boost down in first gear.
Old 12-22-2003, 11:35 AM
Pfieff's Avatar
I used to have a y7 tranny and recently swapped it out for a y8 tranny. It made a world of difference. 3rd gear is where i noticed the most improvement.
Old 12-22-2003, 12:24 PM
kommon_sense's Avatar
EDIT: I have a dx tranny still and still have no traction in first or second gear. Either get the d15b tranny or throw a lsd in the tranny you have. y8 or d15b will always be the answer to a d series transmission question without building a hybrid.</TD></TR></TABLE>
1st gear on all d-series is the exact same, but they do have different final drives. I would do the following :
1) Stop trying to drag launch on the street.
2) Replace compliance bushing on front lcas.
3) Investigate an LSD.
4) Take a look at traction bars (www.jimfab.com)
Old 12-26-2003, 07:39 PM
337 GTI 1.8t's Avatar
Default Re: (94si94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx &raquo;</TD></TR><TR><TD CLASS="quote">Invest in traction bars, and good sticky tires. Otherwise your problem will not be solved.</TD></TR></TABLE>
Umm, i suggest an LSD, Z10 radius rods, an Ingalls engine dampener and a boost controller with scramble boost. These 4 items will solve your problems.
BTW, the 4.25/6 final drive and gearing of the y8 trans is perfect for boost, IMO
96-00 DX 2DR and 4DR had 4.06
96-00 CX/DX hatch had 3.72
Modified by 337 GTI 1.8t at 4:50 AM 12/27/2003
Old 12-26-2003, 07:46 PM
Multi-paradigm
Good ol' Screwtape's Avatar
Default Re: what kind of tranny u run on sohc turbo (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">
Period.
Old 12-26-2003, 09:02 PM
thrty8street's Avatar
lol
speed_demon018
01-07-2009 05:18 PM
afstvx
03-02-2008 12:08 PM
RFd15bhatch
09-15-2005 02:29 PM
egturbo
01-17-2003 01:18 PM
xXx Justin xXx
01-13-2003 12:41 AM
Quick Reply: what kind of tranny u run on sohc turbo
