sohc turbo... should i use a dx tranny or stick with the si tranny????
Re: sohc turbo... should i use a dx tranny or stick with the si tranny???? (Kail18)
im actually running a dx until i fix my si, but all i all, si is better. period. unless your just lookin for fuel economy. that would be one reason to have the dx i guess
Re: sohc turbo... should i use a dx tranny or stick with the si tranny???? (Pengo)
people say "well a LS tranny is awesome for turbo d series", while forgetting that an B series LS tranny and sohc vtec ex/si tranny are almost identical gearing wise.
stick with the ex/si
Re: sohc turbo... should i use a dx tranny or stick with the si tranny???? (JaeOne3345)
i think you meant either LS and B-series, or dx and d-series. but i get the point. and i think you are right as well. the ex/si may be the most closely geared d-series tranny, while the gears and still tall enough to make it the best for boost.
The EX/SI tranny is the best for a turbod SOHC ,hands down..do not try the DX it will be a waste of your time trust me...
also stay far away from the POS Cx tranny
Brian
Brian
Re: sohc turbo... should i use a dx tranny or stick with the si tranny???? (TurbodCX)
Or try to find a JDM D15 tranny, it has an LSD on it...
or ZC tranny with SI final drive.
[Modified by EL-Driver, 3:46 PM 1/17/2003]
Brian
Brian
Re: sohc turbo... should i use a dx tranny or stick with the si tranny???? (EL-Driver)
yeah the lsd tranny would be the best obviously, and alot cheaper than buying a quaife. ZC tranny is a cable tranny. So unless you want to convert from hydro to cable, it wont work.
Mike
Re: sohc turbo... should i use a dx tranny or stick with the si tranny???? (egturbo)
thanks for the info guyz its just that i already have a dx tranny in my car.. i blew my d15 boostin 9 lol so i might pick up this built sohc vtec motor.. should i save money n use my dx tranny? or buy an si/ex one???
Sinner
04-13-2004 09:40 PM
