what hose is this.
Re: what hose is this. (sshaikh01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 »</TD></TR><TR><TD CLASS="quote">what does that do ?</TD></TR></TABLE>
The PCV (positive crackcase ventilation) valve and this is it's purpose:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">The process of combustion forms several gases and vapors; many of them quite corrosive. Some of these gases get past the piston rings and into the crankcase. If left in the crankcase, these substances would cause all kinds of bad things (rust, corrosion, and formation of sludge), so they have to be removed. Back in the old days, they used to be dumped out into the atmosphere through a tube. Once we realized what a problem pollution was in the sixties, the PCV (Positive Crankcase Ventilation) system was developed to take the place of the old "dump tube."
The PCV system uses a hose connected between the engine and the intake manifold to draw these gases out of the engine's crankcase and back into the cylinders to burn with the regular fuel. The only problem to solve is how to keep these gases from going *****-nilly into the manifold and upsetting the required air-fuel ratio. The solution to this problem is the PCV valve.
The PCV valve controls the release of crankcase gases and vapors to the intake manifold. The valve is kept closed by spring action when the engine is at rest. When the engine is running normally, the low vacuum it creates allows the valve to open and release crankcase vapors and gases into the intake manifold for burning. If the engine is idling or you are slowing down, the vacuum level rises and pulls the valve plunger into the valve opening. This partially blocks off the opening so that only a small amount of vapors and gases can be drawn into the intake manifold.
One really comforting feature of the PCV valve is its behavior in the event of a backfire. If your car backfires in the manifold, the pressure makes the spring close the valve completely. With the valve closed, there is no chance that the flame can move into the crankcase and cause an explosion.
Re: what hose is this. (nextelbuddy)
anytime.
I'm full of crazy info from when my **** breaks.
My pcv valve went out on me a few months back and i got pretty pissed when i didn't even know what it was.
So.........I went and found out.
That is the same article I read when i was researching about the pcv valved.
crazyguy
11
09-05-2007 11:50 AM
