pcv valve
Old Dec 10, 2004 | 09:25 AM
coupon's Avatar
Default pcv valve
where is this located on an h22a4? can someone show me a pic?
i want to remove the pcv valve and route a hose underneath the car and put a filter on the valve cover, b/c i dont think the catch cans are worth it anymore
btw, where does the pcv valve connect to in the first place and what does it do? will removing it cause any problems?
Old Dec 10, 2004 | 09:30 AM
coupon's Avatar
Default Re: pcv valve (slowredhybrid)
Old Dec 10, 2004 | 09:46 AM
hOndafienD 04's Avatar
valve cover...then you have a hose that connects it to the intake manifold.
Old Dec 10, 2004 | 10:24 AM
coupon's Avatar
Default Re: (hOndafienD 04)
someone help
Old Dec 10, 2004 | 10:49 AM
LudeyKrus's Avatar
Default Re: (slowredhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">valve cover...then you have a hose that connects it to the intake manifold.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowredhybrid &raquo;</TD></TR><TR><TD CLASS="quote">someone help</TD></TR></TABLE>
Why? The man answered your question!
It is on the backside of the valve cover, towards the right side. It is a plastic valve coming out of the valve cover with a hose that runs straight back to the intake manifold.
Old Dec 10, 2004 | 10:53 AM
coupon's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
It is on the backside of the valve cover, towards the right side. It is a plastic valve coming out of the valve cover with a hose that runs straight back to the intake manifold.</TD></TR></TABLE>
so if a add a hose on the pcv valve aimed to the ground, what do i do with the part on the intake manifold, to get the catch can affect?
Old Dec 10, 2004 | 11:04 AM
coupon's Avatar
ok, here is a pic. if the pcv is the thing on the valve cover than what is the thing in the intake manifold called?
The thing i want to do is add a hose to there 2 locations and add hoses to a small tank located on underneath the car. so can anyone show me where these 2 locations are?
do i have to remove the PCV valve to do this? and how do i remove the valve??
Old Dec 10, 2004 | 11:16 AM
RyanEJ8's Avatar
so if a add a hose on the pcv valve aimed to the ground, what do i do with the part on the intake manifold, to get the catch can affect?</TD></TR></TABLE>
My suggestion to run the hose to the ground doesn't have a "catch can" affect. A catch can "catches" the oil. Running the hose to the ground will just let whatever oil gets by the black box drip on the ground. You would need to remove the pcv valve to do this.
Old Dec 10, 2004 | 11:19 AM
LudeyKrus's Avatar
Why would you need to remove the PCV valve to do that?
Putting a hose from the PCV valve to the ground will let the oil go out of the engine bay instead of back into the intake manifold, but it will not act like a catch can because, as stated above, the oil is not being caught by the can.
The hole on the intake manifold is just called a nipple. You plug it off when doing the catch can.
Old Dec 10, 2004 | 11:28 AM
Hawkze_2.3's Avatar
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
My suggestion to run the hose to the ground doesn't have a "catch can" affect. A catch can "catches" the oil. Running the hose to the ground will just let whatever oil gets by the black box drip on the ground. You would need to remove the pcv valve to do this.</TD></TR></TABLE>
Only problem with that is you have no vacuum pulling out the pressure. My opinion is leave it hooked up to the IM if your not boosted, but with a catch can.
I don't see the point of that diagram's setup. You want a catch can inbetween the PCV and the IM, not the valve cover. Air goes into the valve cover and out the PCV valve, that thing is like a loop with no vacuum....
Old Dec 10, 2004 | 11:30 AM
coupon's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Why would you need to remove the PCV valve to do that?
The hole on the intake manifold is just called a nipple. You plug it off when doing the catch can. </TD></TR></TABLE>
so instread of catching it, it'll dump it right? so it does the same thing just dumping it instead of catching it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
I don't see the point of that diagram's setup. You want a catch can inbetween the PCV and the IM, not the valve cover. Air goes into the valve cover and out the PCV valve, that thing is like a loop with no vacuum....</TD></TR></TABLE>
im going to be boosted, so will the dumping idea not be so effective?
Old Dec 10, 2004 | 11:52 AM
98TypeSH's Avatar
how about i drive down your street dumping oil. Its not exactly biodegradable, and not to metion probably **** off people on motorcycles when the go down due to oil slicks. Use the catch can. Catch it, then drain it. Its really not that hard. Dont be a moron because you are lazy.
Old Dec 10, 2004 | 12:00 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowredhybrid &raquo;</TD></TR><TR><TD CLASS="quote">im going to be boosted, so will the dumping idea not be so effective?</TD></TR></TABLE>
If you're boosted, there will be lots more pressure, so, yes I would take out the PCV valve and just have a nice hole venting to wherever you want....maybe have the catch can catch the oil and then vent into the atmosphere. Many people have even had success putting additional vents on the front of the valve cover...
Old Dec 10, 2004 | 12:05 PM
coupon's Avatar
If you're boosted, there will be lots more pressure, so, yes I would take out the PCV valve and just have a nice hole venting to wherever you want....maybe have the catch can catch the oil and then vent into the atmosphere. Many people have even had success putting additional vents on the front of the valve cover...</TD></TR></TABLE>
how do you take out the pvc valve? and how do u add more vents to the valve cover?
Old Dec 10, 2004 | 12:19 PM
fafsa's Avatar
would also like to know how to do this
Old Dec 10, 2004 | 01:08 PM
Hawkze_2.3's Avatar
Well, I don't really have a write up on, but the valve itself should just pull out. Then you'd need to find a fitting that you could thread into that hole...preferably a 90 degree elbow. Then for the vents, just drill some holes of whatever size you want and find properly sized fittings to thread in.
Summitracing/Jegs/Earls have every type of fitting you could ever want....
Old Dec 10, 2004 | 01:10 PM
coupon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Well, I don't really have a write up on, but the valve itself should just pull out. Then you'd need to find a fitting that you could thread into that hole...preferably a 90 degree elbow. Then for the vents, just drill some holes of whatever size you want and find properly sized fittings to thread in.
Summitracing/Jegs/Earls have every type of fitting you could ever want....</TD></TR></TABLE>
A write up would be awesome please do one soon when u have some time!
Old Dec 10, 2004 | 02:21 PM
coupon's Avatar
Old Dec 10, 2004 | 03:30 PM
Default Re: (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">how about i drive down your street dumping oil. Its not exactly biodegradable, and not to metion probably **** off people on motorcycles when the go down due to oil slicks. Use the catch can. Catch it, then drain it. Its really not that hard. Dont be a moron because you are lazy.</TD></TR></TABLE>
this is a dumb thread either
a)use a catch can
b)leave it how it comes from factory
Old Dec 10, 2004 | 03:38 PM
coupon's Avatar
im gunna make a custom can underneath the car that will catch all of the oil. i have a motorcycle too
Old Dec 10, 2004 | 03:46 PM
u do that and get us some pics..
Old Dec 10, 2004 | 03:49 PM
coupon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">u do that and get us some pics..</TD></TR></TABLE>
seen this done b4, just need to know how to take out the pcv and and how 2 make more vents
Old Dec 10, 2004 | 03:50 PM
hawzke already explained how to do it
Old Dec 10, 2004 | 03:52 PM
Hawkze_2.3's Avatar
Yeah, man, if you can't figure the details out, just take you valve cover to a machine shop or something and tell them what you want to do...
Old Dec 10, 2004 | 03:53 PM
plus you can also search, theres a million threads on diy oil catch cans...some really good ones too
