what does sleeving do to your block????
Old 02-05-2009, 05:27 PM
nengx07's Avatar
Default what does sleeving do to your block????
my block is sleeved from previous owner but what does it do??? im new into engine rebuilds..
Old 02-05-2009, 06:31 PM
batallic's Avatar
Default Re: what does sleeving do to your block????
it makes the cylinder walls thicker, to make it more resistant to cracking due to the hp and heat. if its a shitty tune the heat may still crack the walls though
Old 02-05-2009, 06:34 PM
nengx07's Avatar
so is the bore still gonna be the same after a sleeve????? ex: b20 is 84mm n after sleeve is it still 84mm???
Old 02-05-2009, 06:35 PM
z6hatchboy's Avatar
if it has a good reputable sleeve such as: aebs, darton, golden eagle, ect. then you can always through anything at it. People with h22's (in short) just sleeve the block, put rods and pistons in it with a big turbo and have seen over 800hp easy
Old 02-05-2009, 06:36 PM
z6hatchboy's Avatar
Yes it is, but theres a limit you can over bore them. golden eagle recommend you dont go over 89mm in h-series (stock is 87mm)
Old 02-05-2009, 06:37 PM
sql_civic's Avatar
The bore may or may not still be the stock size. I installed Darton sleeves and bored my 75mm D16 to 78mm.
Old 02-05-2009, 06:47 PM
nengx07's Avatar
yea bc im not sure how big my bore is now... ANYWAY i can check it??? how to measure??? how to be Accurate bc i heard u have to be very accurate
Old 02-05-2009, 06:53 PM
z6hatchboy's Avatar
get a inside diameter micrometer, or just take the block a machine shop and they could measure it easy an tell you
Old 02-05-2009, 06:59 PM
Jimster480's Avatar
ya I say take it to a machine shop. Is it a empty block or what?
Old 02-05-2009, 07:03 PM
nengx07's Avatar
no... motor is still in car... taking ti off tomorrow.. i dont know any machine shop where i live LOL.. any brand name machine shop that might be wolrd wide??
Old 02-05-2009, 07:21 PM
z6hatchboy's Avatar
look in your yellow pages for precision machine shops or something, there everywhere
Old 02-05-2009, 07:24 PM
nengx07's Avatar
aite ill do that tomorrow
thx guys ^^
92VXeg
11-21-2008 10:28 AM
Boostn B20
08-20-2008 03:28 PM
RTW DC2R
02-20-2006 11:20 AM
_Endless_
03-11-2004 06:37 AM
phiberoptik
08-27-2003 10:19 AM
Quick Reply: what does sleeving do to your block????
