are Honda(B16) blocks repairable?
Old Mar 10, 2004 | 12:08 AM
_Endless_'s Avatar
Default are Honda(B16) blocks repairable?
i have a spare block at home but with a hole and some scratches inside when i blew my engine. i understand that the block is aluminum, is there a way to fix it and bring it back good as new without noticing any repair done or is my block good as garbage. thanks.
Old Mar 10, 2004 | 08:26 AM
acy76's Avatar
Default Re: are Honda(B16) blocks repairable? (_Endless_)
I would seek the advice of a good machine shop. Blocks can be repaired, aluminum can be welded - depends on the damage.
Old Mar 10, 2004 | 08:44 AM
RedlinedVTEC's Avatar
How deep are the scratches? Deep enough to catch a finger nail? The maximum you can bore out stock sleeves is .25mm. Anything beyond that you'll want to resleeve it. Is the block itself punctured?
Old Mar 10, 2004 | 01:52 PM
AzG35's Avatar
Default Re: are Honda(B16) blocks repairable? (RedlinedVTEC)
Actually, you can go up to 1mm over stock bore usually. The sleeves themselves are not aluminum, they are steel or iron, forget which one. They can be bored over to use larger pistons.
Old Mar 10, 2004 | 06:33 PM
Lscivichatch92's Avatar
Default Re: are Honda(B16) blocks repairable? (AzSi22)
Actually u can go up to 1mm overbore. but correct me if im wrong but i thought honda sleeves were aluminum. thats why they cant handle much psi when turboed. Most people resleeve there block with golden eagle, darton, etc. cuz theyre iron.
Old Mar 10, 2004 | 06:40 PM
Yes I should have written that the max you can go over using oem components is .25mm.
Old Mar 10, 2004 | 07:55 PM
JDM96SpecCTR's Avatar
the sleeves are not aluminum....im not sure if they are steel or iron or what...but the sleeves are magnetic, while the rest of the block is not....i learned that from messin around with my magnetic pickup tool
Old Mar 11, 2004 | 12:51 AM
_Endless_'s Avatar
the block itself has a punctured hole but all the sleeves are ok, no scratches only the piston and rod on #4 was damaged. the scratches are quite deep but are located under the sleeves where the crank is, its aluminum part already. please refer to the pics.
so aluminum can be welded, can it be welded and sanded back to original-looking?
Old Mar 11, 2004 | 06:19 AM
mmuller's Avatar
Mad Scientist
It looks like the welding will cost youmore than another b16 block
Old Mar 11, 2004 | 06:37 AM
OTT's Avatar
OTT
Yeah the cost would be far too great; But you could keep it as a novelty paperweight and penholder
RTW DC2R
Feb 20, 2006 11:20 AM
Targa4Life
Apr 7, 2005 11:07 AM
cbmprelude
10
Sep 7, 2004 05:10 PM
Mickeyjay36
11
Jun 25, 2004 06:29 AM
BoostedSi
May 18, 2002 08:51 AM
