What Is Code 54? (cel)
Old 06-20-2003, 08:35 PM
B16Hatchcx's Avatar
Default What Is Code 54? (cel)
What does a code 54 mean?
Old 06-20-2003, 08:42 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: What Is Code 54? (B16Hatchcx)
54 Accord Civic CRV CRX Del Sol Odyssey Prelude
96 96-98 97-98 n/a 96-97 n/a n/a
CKF Sensor (Crankshaft Speed Fluctuation)
defective circuit or unplugged / defective sensor
get a helms and go from there. it is in the crank fluctuation sensor. do you have a jdm engine with a usdm ecu? if so there is the problem. jdm engines have no ckf sensor.
Old 06-20-2003, 08:46 PM
B16Hatchcx's Avatar
Default Re: What Is Code 54? (boostedcivicsir)
is ther any way to bypass the ckf sensor?
Old 06-20-2003, 08:49 PM
Mr. Badwrench
if you want to keep it usdm obd2, you need to get a 99-00 si or if it is a c1 or c5 you need a 96-00 oil pump and ckf sensor. you will need the timming cover, the crank sprocket, the woodruff key, all the bolts, and the bracket. all total it is like 400$ and time to take off the oil pan, the oil pump, and re assemble. i have done it but the motor was on the stand. the oil pump is like 90 with my dealer discount, and the ckf is like 230 with my dealer discount. sorry man it isnt cheap.
potatointegra01
02-02-2016 04:23 PM
markovwgti
07-24-2008 11:08 AM
scoobyghost
08-07-2005 08:19 PM
greentegsandspam
04-30-2005 12:12 AM
who00knows
03-18-2004 07:56 AM
Quick Reply: What Is Code 54? (cel)
