weird shifting problem
Old 04-19-2007, 06:59 PM
SoHc94's Avatar
Default weird shifting problem
alright i got a basic 94 ex 5 speed. just exhaust. but my friend has about amile of 4 lane out by his house, like no one out there, no cops no nothing. country in oklahoma so i just decided to see how i kould take this z6. well.. when im runnin it. its all good but when i shift the RPMs dont change. at all. . they sit at the shift point and like hold there. and it loses a crap load of power. i pulled codes. only code is VSS and Fuel system supply and oxygen sensor. i dont no what to look for in my fuel system. cuzi mean fuel filter, pressure, injectors. but they all ran fine in the car the motor was in b4. just b4 we swapped it andthen after it does this.
Old 04-19-2007, 07:04 PM
SoHc94's Avatar
i no my vss is bad. but im wonderng more about the shifting thing. and the 02 sensor. i didnt no that was was it was. i thought it would be like a fuel part. cuz i thought 02 snesor came up as a code primary oxygen sensor.
Old 04-19-2007, 07:08 PM
dannis.'s Avatar
Default Re: (SoHc94)
your right i just read it wrong. but what code is Fuel system supply and oxygen sensor. cause thats a new one for me.
Old 04-19-2007, 07:10 PM
SoHc94's Avatar
Old 04-19-2007, 07:15 PM
dannis.'s Avatar
hahaha sorry 420 for me started to soon. but it could be something as simple as a as clogged filter, injector, ect.
Old 04-19-2007, 07:16 PM
SoHc94's Avatar
yea. u no nething about aht whole shifting ish?
Old 04-19-2007, 07:17 PM
schardbody's Avatar
first thing you have to do is fix the VSS, without it the ECU has no clue how fast the car is going and therefore wont engage vtec, in return you get all kinds of problems.
fix the obvious first.
dannis.'s Avatar
wanna explain to me a little more about whats going on when you shift.
Old 04-19-2007, 07:18 PM
SoHc94's Avatar
ok. but im thinking it might be in my cluster how would i go about checking that?
becuase the sensor worked in another car. but not in mine.
Old 04-19-2007, 08:15 PM
SoHc94's Avatar
alright. when i shift at like 5 or sumthn. it doesnt dropo the rpms at all. it stays at 5 like Waaahhhh... and sounds almost like it hasnt changed gears...
Old 04-19-2007, 11:31 PM
SoHc94's Avatar
bump.
Old 04-20-2007, 05:51 AM
kin413's Avatar
Default Re: weird shifting problem (SoHc94)
does it happend when you are in low rpm??
Old 04-20-2007, 02:39 PM
SoHc94's Avatar
no only happens when im accelerating fast.
Old 04-20-2007, 11:13 PM
SoHc94's Avatar
bump for help... needed soon.
Old 04-20-2007, 11:24 PM
Lord Milferdeen's Avatar
Perhaps your foot is on the gas as you change gears.
Old 04-20-2007, 11:26 PM
SoHc94's Avatar
when i change gears it comes off. then right back on.
Old 04-20-2007, 11:34 PM
John M's Avatar
try a diff vss or cluster
Old 04-20-2007, 11:35 PM
SoHc94's Avatar
i dont have a diff cluster thats where the roblem is i no that. but what i needa no is more about the shifting i have the damn VSS under control.
dejay2014
08-24-2014 09:16 PM
vtec25
05-15-2006 02:07 AM
WTB AUTO EK
01-06-2005 08:55 PM
dcsportsciv
10
11-12-2004 06:44 PM
jakester
06-01-2004 10:50 AM
Quick Reply: weird shifting problem
