Why is my FUEL CUTTING OFF at 4000RPM's sometimes??????????
Sometimes my fuel cut off be hitting at 4k rpm and its annoying not to mention potentially dangerous. Why would this be happening? Also one time it was doing it at 2k rpms.
Re: Why is my FUEL CUTTING OFF at 4000RPM's sometimes?????????? (vtec25)
you mean it gets like boggy feeling right wen the car doesnt go over a certain rpm? if so i got the same problem too im tryin to figure it out too
Re: (1995Ex_Sedan)
I have the same problem. I can pull straight to around 5k, but if i roll a little and then nail the gas, the car bogs and the fuel cuts off.
Re: Why is my FUEL CUTTING OFF at 4000RPM's sometimes?????????? (jdmwannabe3)
well when 4k comes i lose all power and once the revs drop down to like 3k it kicks back on. and yeah i got a CEL code 41 Primary oxygen sensor heater code and a 17 VSS - speed sensor
ok figured it out reset the ecu well first check ur 02 sensor n all ur clips make sure everything is right map sensor intake air temp sensor all the plus n sensor then reset the ecu n ur set too go
Location: Dont You Just Love Lynn Cops, Boston MA, USMA
Re: Why is my FUEL CUTTING OFF at 4000RPM's sometimes?????????? (SkIp_Civic_Ek6)
skip check that rat thats stuck in yho intake pipe
