code 43 fuel problem!!
yesterday my car was idling and then just all of a sudden threw code 43 and it says fuel supply system. defective or malfunctioning fuel supply system. so what could be causing this?
Re: code 43 fuel problem!! (dcsportsciv)
try fixing your 02 sensor first. Most people fix it, and this code will go away. I have this problem, and the 02 sensor unfortunately was not the culprit for me, but hopefully for you that is all it is.
Re: (killer6993)
well i fixed my O2 wires tonight, hopefully it does the trick, ill drive it tomorrow and let you know how its doing. One question, are you also leaning out on #2 and 3 also?
Re: (dcsportsciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsportsciv »</TD></TR><TR><TD CLASS="quote">would this cause me to lean out in number 2 and 3 cylinders?</TD></TR></TABLE>
Check Gas cap (for pressure seal), gas pump, gas filter, clogged injectors, running on low fuel level? Over advanced ingnition? Octane too high? Spark plug temp out of range?
lance_ecl
03-06-2008 08:27 PM
