vtec wont kick
Old 09-23-2010, 10:32 PM
EG-Nate's Avatar
Default vtec wont kick
i just bought a 95 hatch with a b20b bottom end with a b16 head and i was driving it the vtec wont kick in, im not sure if its the vtec solenoid or what. as i was looking around i noticed i didn't have my primary o2 sensor and i was wondering if that could be the problem also. let me know what you guys think.
Old 09-23-2010, 10:39 PM
-__-'s Avatar
Default Re: vtec wont kick
is your Check Engine Light on? also, your primary o2 sensor is pretty important lol. get one ASAP. and yes it could be the problem.
Old 09-23-2010, 11:36 PM
virgineg6's Avatar
i dont think thats causing ur vtec problem, thats just a problem. we need more info to help u out i.e. cel, inop speedo, is it even wired in?
Old 09-23-2010, 11:53 PM
EG-Nate's Avatar
yeah my cel is on also so im kinda stuck i think the cel is on cause the header and **** its obd1 and my speedo and everything works on the car fine.
Old 09-24-2010, 12:45 AM
virgineg6's Avatar
click on the cel sticky on pg1 let us know what it says
Old 09-24-2010, 01:21 AM
forcefedferio's Avatar
yeah step 1 is letting us know what the CEL is on for (could be multiple codes). Also, check your oil, it sounds dumb i know but better safe than sorry considering you just bought the car and i assume know very little about it.
Old 09-24-2010, 04:30 AM
JDM215's Avatar
since its a frank swap make sure its getting enough oil to the head is there any oil lines going to the head or anything? check the ecu maybe he gave you a non v ecu, also make sure vtec is actually wired in, there is soo many things it could be just start trouble shooting
Old 09-24-2010, 06:05 AM
fv8s's Avatar
there are several things that could cause this and i list some of them...
- bad oil pressure (you tapped the head wrong, dowel pins off, oil feed line ran wrong)
- bad ecu (check your cel codes)
- you didn't wire VTEC... link on how to
- bad VTEC solenoid (check to see how much voltage you have at the solenoid)
- low on oil
etc...
Old 09-24-2010, 06:18 AM
fasthatch95's Avatar
Sounds like the wires arnt in tach, plus low oil on b20 oil pumps wont surge enough pressure to vtec and then lead to not letting the pressure lock up vtec to engage. Make sure your pressure switch and solenoid have power and the car is warm. Vtec never works right when the engines cold.
Old 09-24-2010, 06:26 AM
fv8s's Avatar
the oil pump should not make a difference even though it is smart to run a GsR/ITR oil pump, 22t water pump and a timing belt
Old 09-26-2010, 03:42 PM
EG-Nate's Avatar
i got my vtec crakin the vtec wires wernt hooked up right to my ecu thanks for all your guys help!
Old 09-26-2010, 03:48 PM
XRS Joe's Avatar
Thats good news!
JoshJosephKeith
11
04-30-2009 06:29 AM
SleeperGSR
07-02-2008 06:46 PM
Jman8108
04-04-2008 10:25 PM
vietblood87
07-14-2007 09:58 PM
RippSpeed
05-05-2007 07:11 PM
Quick Reply: vtec wont kick
