valve ajustment
Re: valve ajustment
completely possible.......especially if some valves are more out of adjustment than others......causing the airflow to vary both in volume and velocity. if they were all out of adjustment or all the intakes or all the exhaust valves are out of adjustment then id say this would be less likely. its a simple enough process...........might as well check to be sure.
Re: valve ajustment
318 Curves, 11 miles
Re: valve ajustment
What do you mean by you checked everything? In my experience, the most common causes on Civics are air in the coolant and dirty throttle bodies.
Re: valve ajustment
when i say everything, im refering to timing, wires, plugs, tb, etc. like i said everything. regardless, it was the valves. my car is running beautifully now. for those that offered advise and useful input, thank you.
lazyxmofo
05-23-2012 07:04 PM
.RJ
10
04-10-2006 11:19 AM
