Two Dead Cylinders
Old 04-16-2014, 01:35 PM
BrandonHancuff's Avatar
Icon3 Two Dead Cylinders
I've got a 92 eg coupe with a b16a3 swap from a 94 del sol SI. 3rd and 4th cylinders are dead (checked by removing plugs and had no effect on either cylinder) I've got gas shooting out the exhaust and back fire up the yingyang. Strong smell of gas inside the cabin. I had a pretty decent oil leak prior to it going out, would smoke out the bottom and the hood but only if I accelerated hard or hit Vtec. Don't know if that helps any, just giving as much information as I know. Replaced my ECU, injectors, spark plugs and wires. I know I've getting spark and I know I'm getting fuel but it still is running only on 2 cylinders. Haven't done a compression check due to the lack of a compression test gauge. Don't really know where to go from here. Buddy suggested it was my head gasket, I know you can lose compression from that but I didn't think it would ultimately cause two cylinders to die. Please help me out!
Old 04-16-2014, 01:40 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Two Dead Cylinders
Do a compression test. Period. Replacing parts without doing ANY diagnostics is stupid. You can buy, borrow, or rent a compression tester.
Old 04-16-2014, 01:51 PM
JoeBlue's Avatar
Are your plug wires in the correct order? Do you have all of your grounds connected? Bad grounds can cause the ignition to break up and not have enough power to actually light the fuel in the cylinder.
Do yourself a favor, stop listening to your buddy.
Old 04-16-2014, 07:18 PM
Hysterically Calm
TomCat39's Avatar
Get a compression tester and check your compression. I bet #3 and #4 are zero or darn near. The head gasket can blow in between the cylinders so you don't get the other signs of a bad head gasket like oil in coolant or coolant in oil or radiator shooting coolant or bubbling like mad etc. Instead you get two no compression cylinders that are side by side.
The compression test will tell you a lot. If there is compression in #3 and #4 then you know it's either fuel or spark (ignition) problems with those two cylinders.
Old 04-17-2014, 02:38 AM
I'm Huge In Japan
VegasInvasion's Avatar
most likely issue. 1-3-4-2
otherwise definitely head gasket.
Why the hell would you even TRY to hit vtec on less than 4 cylinders?
You should be ashamed. Your engine hates you right now.
platoonsmoke1
10
12-09-2014 10:11 AM
MethodR002
10
04-16-2007 09:42 AM
guymosiris
03-31-2007 12:45 PM
zracer240
04-24-2005 08:35 AM
RCautoworks
04-17-2003 08:03 AM
Quick Reply: Two Dead Cylinders
