my timing is backwards?????
Old 03-25-2003, 03:10 PM
civic dx's Avatar
Default my timing is backwards?????
i just put a y7 head on my d15b7 (free parts) my distributer has to be turned all the way to the back to make it idle best. if i advance it, it shakes alot. on my old head i ran it full advance. do i need higher octane gas? is my timing belt off a tooth? or do i need to idle it up more? other than that it runs good.
Old 03-30-2003, 08:00 PM
Turbo'dMex-A-Keen's Avatar
Default Re: my timing is backwards????? (civic dx)
Hey I got an STR gear for the low,low from Sean. I'll sell it to you....50bucks.
Old 03-31-2003, 05:50 AM
PatrickGSR94's Avatar
Set #1 cyl. to TDC and then make sure the mark on the crank pulley lines up w/ the mark on the t-belt cover, and also the mark on the cam gear lines up w/ the pointer on the upper t-belt cover.
Also make sure you're running the Y7 cam gear. We found out on Lee's car that the D15B7 and the Y8 cam gears are not the same (keyway slightly offset from each other).
Then of course set the ignition timing w/ timing light.
Old 04-01-2003, 05:32 PM
civic dx's Avatar
Default Re: my timing is backwards????? (PatrickGSR94)
i have to use my d15b7 cam gear. The y7 cam gear holds my cam 5 deg. retar. i would have swaped them by now but i am to lazy.
Old 04-01-2003, 05:41 PM
Solbros Owns Me
Evs-One's Avatar
why are you even touching your dist. without a timing light?????
First off:
Get the right tools
Second:
Learn how to use them
Lastly:
Set your timing to specs
Old 04-01-2003, 05:50 PM
civic dx's Avatar
Default Re: my timing is backwards????? (Emerika)
First off:
Get the right tools
Second:
Lastly:
-i have the right tools
-know how to use them
-i have a timing light
what are you talking out about, don't know, don't care.
i have fixed all problems with my head swap, it was the wrong cam gear. this post is old
blacktibby07
05-08-2011 09:46 AM
EJ6sedan
12-22-2009 01:27 PM
johnwohl
05-17-2009 12:27 PM
ef-hatchcrap
01-25-2008 12:45 PM
d15maverick
05-03-2004 09:14 PM
Quick Reply: my timing is backwards?????
