Throwing a code, Can't find answer
Ok, I am trying to fix a 95 civic with the d15b7. When i first start the car it ok but as soon as it warms half way up it goes into limp mode. I don't want to drive it to autozone for them to read it so i just put a jumper wire in the read the code myself. It blinks 4 times and i looked it up and it says "crank postion sensor" But i didn't think that obd1 had that yet, only obd2. Any help would be great.
Re: Throwing a code, Can't find answer (moores55)
Yes, your distributor has a Crank sensor (see diagram below). If it is bad, you will need to replace the distributor subassembly.
H-T White Ops
Btw, Autozone can't scan cars that are pre-OBDII. Well, unless an employee happens to have the correct plugs and scanner and is willing to let you use it (which is highly unlikely).
whereiscarmensandiego
15
10-23-2008 11:16 PM
Spade
07-30-2002 02:05 PM
