CEL
Old Dec 6, 2011 | 06:26 PM
hit_it's Avatar
Default CEL
hey everyone. ok so i have a 1990 integra that i just got a couple days ago. it has an obd0 harness, obd1 b18a1 bottom end, and obd2 b18b1 head. the code is for a crank angle. i didnt think the b18a1 had that on it. any advice or answers would be greatly appreciated. thanks!
Old Dec 6, 2011 | 11:45 PM
TheRealTegger's Avatar
Default Re: CEL
What's the actual code number? Code 4?
The B18A1's distributor contains three sensors: TDC, crank, and cylinder-position.
Do you have any symptoms besides the code? Have you tried clearing the code to see if it comes back?
Old Dec 7, 2011 | 08:20 AM
hit_it's Avatar
Default Re: CEL
Code 6...code is thrown, idles low and wants to die sometimes. Going to try to reset it later. Thanks
Old Dec 7, 2011 | 09:46 AM
hit_it's Avatar
Default Re: CEL
Tried to reset it and it just stays on
Old Dec 7, 2011 | 11:25 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: CEL
Code 6 is coolant temperature sensor. Its the black sensor to the right of the green on in this pic
Old Dec 8, 2011 | 06:45 AM
hit_it's Avatar
Default Re: CEL
thats weird. i looked up online and read that code 6 for 1990 integra's is crank angle...i will try ur answer first and go from there. thanks so much
Old Dec 9, 2011 | 08:21 AM
hit_it's Avatar
Default Re: CEL
Ok so looked at my motor and it looks nothing like the pic. Idk what to do. Any other advice? Thanks.
Old Dec 9, 2011 | 08:27 AM
1911Goodness's Avatar
Default Re: CEL
what ecu are you running, it is looking for that sensor and not finding it is my thinking
Old Dec 9, 2011 | 09:33 AM
hit_it's Avatar
Default Re: CEL
Actually I believe I found it. A wire was broke at the sensor. Going to fix that and see. Thanks
Old Dec 9, 2011 | 09:38 AM
Default Re: CEL
nice, hope thats it, fixing a wire is alot cheaper than buying a new ecu lol
bababab18
Sep 30, 2010 01:30 PM
O RLY
Jul 6, 2010 02:06 PM
Sephrin
Nov 10, 2009 04:24 PM
LoseRPunKx182
Aug 4, 2005 01:50 AM
foesicks
Jun 4, 2003 09:47 AM
