need ecu code help quick
Old Mar 18, 2002 | 01:37 PM
Rboosted717's Avatar
Default need ecu code help quick
I need code 8 & code 82; and what to trouble shoot from the helms manual. thanks
Old Mar 18, 2002 | 01:40 PM
infamousALLMTR's Avatar
Default Re: need ecu code help quick (Rboosted717)
code 8 is- TDC position, so your cam is off?
sorry dont have code 82
Old Mar 18, 2002 | 02:52 PM
D's Avatar
D
all those expensive parts and no $60 for a helms?
Old Mar 18, 2002 | 02:53 PM
AssPenny's Avatar
Default Re: need ecu code help quick (D)
Its 65 bux Just ordered one today for the cr-v
Old Mar 18, 2002 | 02:58 PM
Its_real&its_spectacular's Avatar
New User
TDC sensor is inside the distributor and is most often seen when a distributor's bearings are failing. Take the dist cap off and if you see any rust in there, it's time for a distributor...
Old Mar 18, 2002 | 03:31 PM
Austin's Avatar
Default Re: need ecu code help quick (Its_real&its_spectacular)
Hey Mike...you might want to take a look at the link that I borrowed from C-Speed racing.
Austin
http://www.c-speedracing.com/faq/05.html
Old Mar 18, 2002 | 04:53 PM
hey I didn't post this, but I know who did! Thanks for using my name! lol
Anyway here's a response that someone just IM'd me:
Well, the TDC sensor is located in the distributor, along with the CYL & CKP sensors. To replace this sensor is to replace the whole damn distributor housing (which does not include the coil, igniter and such...only the 'cage'). To check operation, you either need a meter or scope. With a meter, you can check the coils resistance and the peak-peak AC voltage being produced (should be about 7V at 2000 rpms). With a scope....same procedure, but this would allow you to SEE the waveform and if there was something wrong with it...like perhaps the distributor bushins were going south...this would be seen on the scope.
Let me know if you get that fixed! I'm really curious to see what was going on.
Oh and yes I have a Helms and the R addition. Heck how do you think I do most of my work! This person though who posted didn't have a helms that was in his reach at the time!
Here's a picture I took of the selected pages:
http://www.imagestation.com/picture/...d.jpg.orig.jpg
http://www.imagestation.com/picture/...4.jpg.orig.jpg
http://www.imagestation.com/picture/...e.jpg.orig.jpg
[Modified by Rboosted717, 6:10 PM 3/18/2002]
Old Mar 18, 2002 | 06:26 PM
ITR#132's Avatar
Hey whats up Mike
I used your username because it was still logged on at the shop. Anyways I checked everything(Checked the cam timing, base timing-which by the way was at 20 deg., spark plugs, ecu wiring, distributor, fuel injectors, fuel press., dist. wiring, fuel controller) and couldnt find anything wrong and reseted the ecu at least 4-5 times before the codes didnt come back. I am still baffled as why I got them.
Oh, It was code 8 and code 73, not code 82 as I originally posted using your username. Now hopefully whatever that caused the codes will not pop up again.
Old Mar 18, 2002 | 09:06 PM
Austin's Avatar
Default Re: need ecu code help quick (ITR#132)
Hey Tim...I hope that you figure it out, I've got a code I can't figre out too
Mike...on the way home last night I saw Leo fly by me as he killed a riced Prelude...not all that often that you see a turbo itr fly by you in the Burlingame area.
Austin
cornfed
Engine Management and Tuning
Jan 27, 2012 02:49 AM
Schaz
May 16, 2005 07:34 PM
GuyInASpeedo
Sep 25, 2003 07:05 PM
se93
Sep 23, 2003 07:25 AM
Spade
Jul 30, 2002 02:05 PM
