Thermostat Problem?
Old 11-29-2004, 06:44 AM
Downs's Avatar
Default Thermostat Problem?
Hey it's starting to get cold here in Idaho (-2 this morning) and it seems like my car is taking forever to heat up. Once the heater gets warm, it's only warm not near as hot as it used to get. And if you let it set for 10 or 15 minutes, it gets cold again. My car doesn't overheat or anything like that. I was thinking thermostat, but I just wanted to a second opinion. It's a 98 HX never had thermostat changed. I haven't checked coolant yet, but I will before I change the thermo. Thanks
Old 11-29-2004, 07:12 AM
snatch's Avatar
Default Re: Thermostat Problem? (Downs)
Thermostat could be stuck open. I just had to replace mine due to this.
Old 11-29-2004, 07:13 AM
wilsel's Avatar
Default Re: Thermostat Problem? (******)
That or a previous owner could of taken the thermostat out completly. Are you the original owner?
Old 11-29-2004, 07:14 AM
lohatch's Avatar
yah that is my guess too. check it out
Old 11-29-2004, 07:57 AM
I forgot more about hondas then you will ever know....
Rodney's Avatar
Location: hop,skip, and a jump from the city,, new friggin york, USA
yes sir, i concur with the masses. swap your thermostat.
*sidenote: buy an oem thermostat. aftermarket ones are junk. just a fyi
Old 11-29-2004, 08:19 AM
eg92b16a2's Avatar
Default Re: Thermostat Problem? (rodney)
autozone work fine if you get the failsafe ones. you must ask for the failsafe one. they are around $14.99 and they will stay open if the thermostat malfunctions.
Old 11-29-2004, 08:49 AM
93CivicSI's Avatar
wide open or no thermostat will cause your car to not heat up as well, additionally, old antifreeze or not having the right mix will prevent your car from heating up as well.
Old 11-29-2004, 09:13 AM
Downs's Avatar
Default Re: Thermostat Problem? (93CivicSI)
Thanks guys. I am not the original owner bought it in 99. Also I figured that I would get an oem one since I can get it for the same price. Thank you for your help
simplegreenmachine
13
12-12-2009 04:07 PM
crxfreak1117
01-28-2008 04:07 PM
jmkc
11-05-2005 09:24 AM
superstud
10-14-2004 12:44 PM
delSolLS
01-16-2002 01:06 PM
Quick Reply: Thermostat Problem?
