97 Integra TROUBLE CODE!!!!!!!
Old Apr 10, 2006 | 04:43 PM
Anti-Drama Queens's Avatar
Default 97 Integra TROUBLE CODE!!!!!!!
the code is p1362 ... something about ignition misfire
has anyone had this problem ? and what did u do to fix it? i looked in my trouble code book and one thing they say it would be...is the crank sensor....u guys think that sounds right? any input is appreciated
Old Apr 10, 2006 | 07:20 PM
Ruben19's Avatar
are you sure that is the right code
according to a website.
P1362 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) No Signal
P1362 Top Dead Center (TDC) Sensor No Signal
That will be your Camshaft position sensor located inside the distributor.
Have you done a timing belt job.
Old Apr 11, 2006 | 04:47 AM
havent touched the timing belt at all....its my friends car and with the check engine...he will not be able to pass inspection
Old Apr 11, 2006 | 07:34 AM
Ruben19's Avatar
if you have an engine light.
car will never pass.
just replace the camshaft position sensor in the distributor.
is not sending a signal to the ECU
Old Apr 11, 2006 | 03:58 PM
yeah found out it is one of those sensors...but its the crankshaft sensor...theres like 3 of them...cam, top dead center, crank but according to the dealership service guy...he said that they dont have the camshaft sensor in these years or something..instead they used the crankshaft sensor : /
pos94accord
Jan 25, 2009 05:29 PM
snatch
Dec 13, 2004 04:28 PM
JpReTz
Jul 14, 2004 04:17 AM
wickedxboi
Oct 28, 2003 08:12 PM
SpoolinEK
12
Jun 18, 2002 05:32 AM
