HELP!!! Code 8 - TDC - top dead centre sensor
Re: HELP!!! Code 8 - TDC - top dead centre sensor (EG Civic)
sounds like you may have slipped a tooth on your timing belt. Yank the cover and see if it's in good shape. That's where I'd start...
Re: HELP!!! Code 8 - TDC - top dead centre sensor (Bakeoff)
what do you mean by slipped a tooth...i didn't mess around with anything in the engine...could you tell me where the sensor lays?
i think that sensor is inside your distributor if im not mistaken... and you can jump a tooth just by driving... it happens we have "timing belts" not a chain so sometimes they tend to slip especially when old
Re: HELP!!! Code 8 - TDC - top dead centre sensor (JDMinPorterville)
well it's a 99-00 gsr integra..you think it would wear down...and i believe the engine is about 35k..
ohh... dunno but i do think the sensor is in the distributor... if you can find someone that has a GSR distributor try putting it on and seeing if the problem is healed
It's actually popping a code 8 and a code 23..which is knock sensor i believe..could that play a role in the code 8?
Re: HELP!!! Code 8 - TDC - top dead centre sensor (DOHCtorTHRUST)
does the motor seem to be running properly? The tdc and the cyp sensors are both on the shaft of the distributor for your motor, try a buddies good dist and see idf the prob clears up, if not try an ecu.. if you still have the problem then i would think the sensors are trying to tell you somthing..
[Modified by BakedCookies, 1:32 PM 6/17/2002]
Re: HELP!!! Code 8 - TDC - top dead centre sensor (BakedCookies)
i have a obd II LS/crv distributor..could i pull the sensor otu of that..if so..is there a picture or something that i can tell how it look like?
BOTH tdc and cyp sensors are made to the shaft of the distributor, while i am not 100% sure you cannot remove them, I have always been told the best thing to do is replace the distributor... give import auto salvage a call he might have what you need and for probably less than 100 bucks...
Bserieskllr
09-11-2004 05:43 PM
sander
04-25-2003 07:46 AM
