tachometer help on 1997 civic ex
I wired everything up on the tach except for the tach wire.
does anyone know what color the tach wire is on the distributor or know where i can get a wiring diagram for it.
its pin A20 (obd2a) the wire is yellow and green u can pick it up at the ecu connector...if your looking at the ecu right side up facing you with the clip on top... the longest connector to the left count 9 pins on the second row and thats it.
Tyson
40
06-04-2009 04:24 PM
1997, adding, change, civic, del, distributer, dx, fluctuating, honda, sol, tach, tachometer, tacometer, wire, wiring
