sway bar for ek hb?
Old 03-14-2002, 09:55 PM
GokuSSJ4's Avatar
Default sway bar for ek hb?
i have an EK hb and it doesnt come equip with a sway bar(not strut bar)in the front , at this moment im running a SI sway bar on the rear . but i want to know whats a good sway bar for the front ? will the SI ront sway bar fit??
Old 03-14-2002, 10:08 PM
GokuSSJ4's Avatar
Default Re: sway bar for ek hb? (Spoon1)
ttt
Old 03-14-2002, 10:40 PM
GokuSSJ4's Avatar
back to the top
Old 03-14-2002, 10:49 PM
Mario's Avatar
Si front swaybar will fit. IF you use the following parts.
1. Si front forks
2. Si front lower control arms
3. Proper bushings, etc.
Old 03-14-2002, 10:55 PM
GokuSSJ4's Avatar
Default Re: sway bar for ek hb? (Supersonic DC2)
will it make a difference if im running itr 5 lug?
Old 03-14-2002, 11:20 PM
GokuSSJ4's Avatar
up
Old 03-14-2002, 11:40 PM
uc0083's Avatar
No it will not. I have that set up and 5-lug and it fits fine.
Old 03-15-2002, 09:19 AM
GokuSSJ4's Avatar
Default Re: sway bar for ek hb? (uc0083)
what set up do you have and what did you need ?
Old 03-15-2002, 09:34 AM
Jackson's Avatar
you are going to need the bar, the end links, lca's, forks(because the lca is bigger) and it bolts right up to your subframe. you have holes for it already. you need the lca's so the endlink has a spot to bolt up to. this set up is really good, i am running si/ctr front and itr rear sway with beaks srk. makes a huge difference.
Old 03-17-2002, 10:07 PM
GokuSSJ4's Avatar
Default Re: sway bar for ek hb? (Jackson)
but for rear sway bar in order to run itr dont you need to modified some??
Old 03-17-2002, 11:11 PM
Jackson's Avatar
you need the beak's srk. reinforces the subframe so it wont rip out.
drew1987
01-08-2008 08:41 AM
turnsignalandy
05-28-2006 09:14 PM
aak
Suspension & Brakes
05-22-2006 09:27 AM
JDMCRX
04-26-2003 10:08 AM
Greasemonkey
14
10-19-2002 07:27 AM
Quick Reply: sway bar for ek hb?
