So I finally saved up enough money for an engine...now what?
It's been 4 months...And with not buying anything but bread and water to eat and picking up every penny that comes to sight I saved up 6 g's...I've been wanting to go hybrid for quite some time now but I dunno what to get? All I know is, that I will not be going all motor.
I've been thinking of getting a b18c5 but my friend tells me because of the high compression it will blow? Is this true? Is turbo a no-no for this engine? If not, what will I need??????
Can you guys help me??? PLEASE!!! :\
Re: So I finally saved up enough money for an engine...now what? (EXtremeYLODRGN)
not true, if you bulit the motor rite, it can take boost..
if all you have is 6gs.. I suggest you go with a b18b and boost it.. should take about 10-11psi with stock internal, and save the rest of the money, in case anything break, or you can use some high lift cams with them..
you then should be a happy man............
Re: So I finally saved up enough money for an engine...now what? (chusai)
So it's totally possible to ru a b18c5 motor w/ Drag Turbo in my 94 ex? What am I gonna need for this? Money is not a problem for me considering my current job. So yeh...Lay down some 411 on me...Cuz I really wanna go b18c5...
So it's totally possible to ru a b18c5 motor w/ Drag Turbo in my 94 ex...
If you want to go turbo there is no reason to get the B18c5. you are spending more money on stuff that you are going to change if you want to run a lot of boost. but if you really want to and do it right I would do the following: Rods, pistons(low compression), valves, valves springs, stock crank should be ok, block guard, boost controller, turbo timer, upgrade injectors, fuel rail, intake manifold, someone help me out. I'm not up on all my turbo stuff
dont waste money on b18c5 if your going turbo. it's just a waste. if you only have 6000 and you want the b18c5 AND turbo, it's not going to happen. That's why you should go for the LS engine and do it right. You will be much happier in the long run.
Re: So I finally saved up enough money for an engine...now what? (SuperDragII)
yes this is entirely possible.....I know several type R owners running that exact set up on stock motors.
the gears are longer, (not longer then the b18b) and the CR is not that high .
if you really plan on running a turbo then your best option is running a GSR motor
b18c1 and with the money that you save , you would be able to buy both at the sametime ,gsr motors go for 3000-3400 and with that it gives you a good amount the get your self a turbo kit!
Re: So I finally saved up enough money for an engine...now what? (Spoon1)
I'd say you should go with a b18b or a b20b, and turbo it. You will get a lot more torque then a b18c5. If you have a c5 the compression ratio is way to high. You will blow your motor if you want to up the boost. The c5 was built for all motor. If you want FI then get a b18b/b20b, resleeve it, low compression pistons, lightweight rods, injectors, fuel pressure regulator, fuel rail, msd ignition, some nice cams, titanium retainers, valve springs, turbo timer, and boost controller. You will be able to turbo the hell out of it. Run like 20 psi of boost. That would be bad A$$!
