Running rich before, now burning oil.
93 Civic w/ B18C1. The only modification is Skunk2 Intake Manifold. Everything else is stock. So when i did the swap it was running rich; Black smoke on bumper. I Reset the ecu and it was still running rich. Due to school and work, i have to time to fix. I drove the car running rich for about a month and now its burning oil; Blue smoke from muffler. I need to know what happen between running rich and burning oil. How does running rich leads to burning oil?
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
Re: Running rich before, now burning oil.
how many miles on you'r engine ? when i put the s2 mani on my GS-R it started to ran seriously rich i only wish my plugs looked like your's mine you can't even see white just pure black with lots of carbon build up.
No. You need to pull the rotating assembly and have a machine shop hone the block. You then need to replace the rings while reassembling the motor. While you have it all apart, you might as well replace the main bearings. You can get away without pulling the rod bearings, though.
I changed my oxygen sensor on my 1993 honda civic hatchback dual carb but the light on the dash still on is there more then one oxygen sensor?
