replacing clutch but ran into problem
so this is like my 5th time replace a clutch. now i have every bolt off. my problem is the dam tranny will not come off. what should i use to remove it. its like the dam thing is stuck. i tried wd 40 in the bellhousing bolt holes but its still not coming loose. im pretty sure all the bolts off. there are i think 5 bellhousing bolts. starter is off and axles are off. wtf please help.
Re: replacing clutch but ran into problem (HXvtec)
on my d, we got it cracked a little and used a hydraulic seem strecher, i think thats what its called, and it popped it right apart
also, check your helms to make sure you have all the bolts out, dont want to break anything,
also, what kind of eninge/trany, d or b
you can try jacking the tranny up and putting it in a bind. also, make sure you have all the bolts out, triple check before using force to seperate them.
Re: replacing clutch but ran into problem (t0p_sh0tta)
You are going to have to pry it off but like everyone else is saying, MAKE SURE ALL THE BOLTS ARE OUT FIRST!
ringgold
05-23-2004 06:20 PM
