Replacing bad Y8 with a Z6, keeping OBD2
Old 02-03-2009, 07:07 PM
MinorObsession's Avatar
Icon6 Replacing bad Y8 with a Z6, keeping OBD2
Has anyone done this? Only replacement motor I could find that was single cam VTEC, is a Z6 motor. I have the Y8 out, took of intake mani, dist, etc...... The thing that is throwing me is the crank sensor. Has anyone else done this without rewiring the car, can I flush out the old oil pump and bolt it on the Z6 motor? Thus giving me the mounting location for the sensor. HAVE to make this work.
Old 02-04-2009, 04:00 AM
Seagull Management
94EG8's Avatar
Default Re: Replacing bad Y8 with a Z6, keeping OBD2
Its been done before. As far as the CKF sensor goes simply perform the CKF fix as seen here ---> http://technet.ff-squad.com/ckftrick.htm
You will also need to build a custom distributor, use the Z6 distributor case and the shaft/bearing plate assembly with the Y8 sensors.
Old 02-04-2009, 05:19 AM
THANK YOU 94EG8 this rocks, exactly what I was looking for.
Old 02-04-2009, 06:51 AM
Seagull Management
94EG8's Avatar
Forgot to add:
Timing will be somewhat off with the OBD2 ECU (I don't know just how far off)
You wont pass emissions in some states
Old 02-04-2009, 09:54 AM
no emissions in michigan, so far. thanks
Old 02-04-2009, 01:17 PM
Everything is ok, but what do you do about the knock sensor? none present on the Z6 block? Will this throw a cel?
Old 02-04-2009, 02:17 PM
Seagull Management
94EG8's Avatar
You should be able to drill and tap a hole for knock sensor, the Z6 doesn't have one, and yes it will throw a CEL.
FSTSOHC
10-11-2011 05:40 AM
bigpwr
06-19-2010 11:20 PM
Budd9880
08-23-2009 01:04 PM
sdj02
08-21-2008 03:02 AM
chue_li
10
03-14-2005 02:45 PM
Quick Reply: Replacing bad Y8 with a Z6, keeping OBD2
