Question between Si and Vx hatchback
Old 09-21-2008, 03:26 PM
dutchman5's Avatar
Default Question between Si and Vx hatchback
I want to know about two of vehicles. Does Si hatchback comes with sunroof in only model? What about VX?
Old 09-21-2008, 03:49 PM
dkeh3's Avatar
yes only si comes with sunroof. vx doesn't.
Old 09-21-2008, 07:39 PM
batallic's Avatar
Default Re: Question between Si and Vx hatchback (dutchman5)
the ex also comes with sunroof
Old 09-22-2008, 02:21 AM
dutchman5's Avatar
Default Re: Question between Si and Vx hatchback (batallic)
Yeah I know ex model come with sunroof. The reason why I ask this question is because I purchased a shell hatchback that displayed VX model but it come with sunroof! I had checked vin number and it shows that it has a Vx model...Is there any other way I can check if my hatchback is Si or VX?
Old 09-22-2008, 03:24 AM
dumpedEM1's Avatar
could be an aftermarket sunroof..
Old 09-22-2008, 04:55 AM
Seagull Management
94EG8's Avatar
All I can think of is someone put in an aftermarket sunroof, or cut the roof out of an Si hatch and welded it in.
Old 09-22-2008, 05:10 AM
Former Moderator
B18C5-EH2's Avatar
Default Re: Question between Si and Vx hatchback (94EG8)
Easiest way to tell the Si chassis from VX chassis is the VIN number:
Si = 2HGEH3... for the VIN (only Si has the EH3 designation)
VX = 2HGEH2... for the VIN (as does the CX and DX as well)
Aside from that I could go on listing the model differences between the two such as:
Si has rear discs - VX has drums
Si had FACTORY power sliding moonroof - VX did not
Si had power mirrors - VX did not
Si had two mirrors - VX did not from the assembly line (though dealers installed many)
Si had cruise control - VX did not
Si had rear washer/wiper - VX did not
Si had clock - VX did not
Need I go on?
I say someone had an aftermarket roof installed on that VX.
Old 09-23-2008, 09:09 PM
dutchman5's Avatar
Default Re: Question between Si and Vx hatchback (B18C5-EH2)
I ll take headliner out and check if it s come with stock or weld sunroof...
thanks
Old 09-23-2008, 09:13 PM
Hanmin's Avatar
pictures would be nice=]. maybe vin swapped? does the quarter panel have side moldings?
Old 09-24-2008, 02:53 AM
dkeh3's Avatar
ditto....pics would help. cx and vx = no side moldings. dx and si, but si has sunroof. the information b18c5-eh2 just gave you should already be enough for you not to take out the headliner. and you could check out the interior patterns.
Old 09-24-2008, 06:16 AM
shifty35's Avatar
Default Re: (dkeh3)
Could always be a dealer installed option.
Old 09-24-2008, 02:00 PM
H-T White Ops
NOFX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dutchman5 &raquo;</TD></TR><TR><TD CLASS="quote">I ll take headliner out and check if it s come with stock or weld sunroof...
thanks </TD></TR></TABLE>
No need to even remove the headliner.
Just open the moonroof.
Is the rubber seal on the glass or on the roof? If it's on the roof, it's aftermarket.
Old 09-24-2008, 03:30 PM
dutchman5's Avatar
Default Re: Question between Si and Vx hatchback (NOFX)
Si has rear discs - VX has drums-- yes i got drum
Si had FACTORY power sliding moonroof - VX did not- yes it had sunroof but look extacly like stock!
Si had power mirrors - VX did not .... yes i had power mirror on both side
Si had cruise control - VX did not... dont know about cruise.
Si had rear washer/wiper - VX did not .... not sure
Si had clock - VX did not... not sure
I think u guys right..someone could be weld stock sunroof on it.. i ll take picture tonight .
Modified by dutchman5 at 6:37 PM 9/24/2008
Dead CIVIC
15
03-05-2011 04:26 AM
halfkoreanboy
28
03-22-2009 10:44 AM
Do_Ster
57
07-07-2003 03:43 PM
tanjulio
04-20-2003 12:47 AM
RStoR
06-02-2002 09:16 PM
Quick Reply: Question between Si and Vx hatchback
