Question about wire tuck
hey so I did a headlight harness wire tuck on my 99 civic and i saw a lot of people were cutting a hole in the fender so thats what I did but just wanted to know should I be concern about the whole being open for water or whatnot going in the cabin? I checked everywhere but no one says anything about those holes after. heres a pic
ive seen people cut the end of that upper fender rail off so they could run the harness through that tube of steel to the headlights.... I don't remember drilling any holes like that when I did mine.... I used wire holding clamps to hold the wires up from the wheel.
i didn't cut a single thing on my car. I ran the wires through the door grommet and ran them all through the tube in the fender up to the front. I didn't have to cut any wires or extend them at all. They fit perfect that way
i want detailed pics on this.... because i need to do a mild tuck and need detailed pics before i start... yes i know i am being a baby but i have a 2000 dollar gallon of paint on my car and im weary about removing the fenders cause i don't wanna scratch anything up.
http://www.clubcivic.com/board/showthread.php?t=213771
Now I see why the door grommet is an issue.
I'm in the middle of this atm ill post results later when done. Relocated battery and fuse box. Headlight harness tuck. I'm trying to avoid cutting anything.
i did a headlight harness tuck, battery relocation, fuse box relocation into the glovebox and i didn't have to cut a single wire or piece of metal with the fenders off. The only thing i had to do was open up the hole of the channel on the inside of the fender to fit one of the plugs through
This is what I did when doing my tuck. I used a hole saw, i think it was 1 1/4 inch, and the plugs fit through just fine. I did although have to do some dremeling to get the plugs through the other hole. (the one in OPs pictures, but above the hole his harness is through)
chbek9
Jun 24, 2010 07:28 AM
Frost7177
Oct 18, 2009 08:30 PM
Mixmasta
Jan 27, 2009 05:32 PM
sageuvagony
Oct 4, 2008 09:07 PM
