IN THE PROCESS: Minime Y7/y8 issues
I was wondering , i was pinning the ecu and was doing the 2 step iacv fix for the 96-98 and needed to take out the orange wire on plug "a", if i cut the wire, do you know if the ecu will read the pin if it is just the pin left on the plug with a small length of wire? or will the ecu read it and throw a code? thanks!
Re: IN THE PROCESS: Minime Y7/y8 issues (Civiclx)
also when taking out the y7 head, i got some oil in the coolant rings around the pistons, do you think i can just flush this out with running water? thanks again, suggestions?
i did the y7 mini-me and all that pinning crap, it was a bitch. I can help you out. Did you drain the oil and coolant before taking off the y7 head? PM me and I can walk you through the WHOLE thing. I didnt do the 2 step IACV thing your talkiong about though. What ecu r you using?
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">i did the y7 mini-me and all that pinning crap, it was a bitch. I can help you out. Did you drain the oil and coolant before taking off the y7 head? PM me and I can walk you through the WHOLE thing. I didnt do the 2 step IACV thing your talkiong about though. What ecu r you using?
i drained all the coolant and the oil, i did the 2 step iacv, what did u do?
Re: (Civiclx)
also, on the y7 head, there wasnt a coolant or vacuum hose right in the middle of the back of the head like the y8 has, do i just plug up this hole?
Re: (Civiclx)
Thanks turbotime
does anyone know where the line behind the "D" in HONDA goes on a y7-->y8 conversion?? its a line that points straight up when loooking straight down behind the valve cover.
Re: (Civiclx)
here is the EX (D16y8) Head:
here is the DX (d16y7) Head:
Here are the lines going from the new y8 head to the y7 block
If you look at EX models (d16y8) there is a sensor the mystery y8 line goes to that is not present here on the y7 block, what the hell do i do?
I think that you are talking about the EVAP purge solenoid, it is a black sensor with a vacuum hose in and out and a plug. If that is what you are speaking of, the bottom nipple from the intake manifold goes to one side of it and the other side goes to the charcoal cannister. You should have one on your Y7 manifold bolted to a black bracket. HTH.
