EK w/ b18c5 running like hell!!
ok guys heres the deal ive had my EK w/ b18c5 for 3 weeks now, only mod is short ram intake. For about the last 2 1/2 weeks everything has ran great!! but about 3 days ago my car started hesitating and that same night we got a ton of rain and car was hesitating VERY BAD. then the next morning after the motor warmeed up and was idling the rpms would drop very low (about 200-400) and shake very badly, but the hesitation problem while driving went away. later on in the day the idleing problem became less constant. Now today it drove fine all day, but the idling problem happen once again on my way home tonight! Now the motor has around 25-30k miles on it. i know when you swap a motor you should always have it tuned. Well it hasnt been, but why is it just now all the sudden running like this insted of beeing a problem for the past 3 weeks! it also blow dark gray/black smoke at WOT so im sure it needs some fuel tuning. But what do you guys think!!! let me know ASAP!!!
Re: EK w/ b18c5 running like hell!! (civicdxtyper)
sounds like maybe the ecu is maybe getting a bad connection soemtimes...dropping a cyl. missfiring or something make sure everything is tight...um maybe something is the distributor is going bad??? just an idea
Re: EK w/ b18c5 running like hell!! (All MTR TODA HATCH)
After I did my motor swap I had a similar problem, it turned out to just be my spark plugs....threw some new ones in and it was fixed. Maybe your fuel filter is clogged??? As far as smoke goes, I dont know. Worst case scenario, it could possibly be your rings.
Re: EK w/ b18c5 running like hell!! (JDMjdawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMjdawg »</TD></TR><TR><TD CLASS="quote">yeah probably....rings means white smoke.</TD></TR></TABLE>
no rings mean blue smoke white is water..
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">not positive but i think black smoke is that your running rich. but its better to run rich than to run lean</TD></TR></TABLE>
yhe i may try giving it a little tune up, and the smoke is darkgray/black. SOme one also said it about timee for a valve adjustment?? how often should that be done
Re: (Manuel)
my B18C1 had a problem similiar to this.. happened while under WOT.. damn wire came off the dizzy thought i fuckered up my motor.. always good to change plugs/wires
Bwhit12
10-12-2011 02:34 AM
spooncivic99
06-04-2008 08:28 AM
isaacson06
15
08-28-2007 12:40 PM
