plz help
plz help
I have a b16 vtec swap came off 99 si put on a 99 civic ex coupe just recently bought a b20 vtec gsr head came off an eg got the whole swap put the whole swap on my 99 ex civic coupe I use my wire hardness from the b16 vtec also the distrubator connect with the hardness Also i got a p28 virgin with and ob2 to ob1 jumper the car turns on but the car dies after driving for a bit like the battery dies it idles funny when you gas it bogs out unless I keep it on high rpm I don’t know what to do plz help
Re: plz help
That ecu isn’t for that swap you need to get it chipped and tuned. Your running a 2.0L with gsr Head that’s not made from the factory. The ecu you claim is virgin and is made for a sohc vtec (correct me if I’m wrong) 1.6L or 1.5L or whatever... you need to send your ecu to phearable or whoever can chip it and then order a basemap chip for your setup and then take it to a dyno shop to get it tuned.
JDMRican
10-22-2010 12:55 PM
xlasianizelx
03-14-2008 09:57 AM
andreysibiris
07-31-2005 02:44 PM
