Piston ring replacements
I have an old d15b7 and was thinking of doing a mini swap. I think the piston rings are going because it is burning some oil. I am wondering if it is hard and how costly to replace the rings and probably pistons while i am down there. Or if i should just buy a new B16a and swap that in. Thanks for any help
Re: Piston ring replacements (civicdxcpe)
Pistons rings depending on where you purchase them can range from $20 a cylinder to $40 a cylinder.
Now before you replace those you need to measure to see if its worth fixing up that motor, given you will need a new headgasket, head bolts, ect ect
If your going to BUILD BUILD a motor for turbo ect. i would replace the main/rod/head bolts with ARP's. might as well do it while everything is out. u will need a new headgasket. piston rings shouldnt be to much. try shopping around. i know prostreetonline carries alot of OEM parts. might wanna try there
Solbros Owns Me
Re: (JDMlyfestyle)
only run OEM rings. You'll need to hone your cylinders tho. Most of the time you can get away with running a berry bush with some ATF through them real quick. Don't expect it to last as long as a fresh build before it starts burning oil
If you are going to do it, do it right.
climb_on
16
09-05-2007 08:49 PM
