Procedures to replace piston rings.........
Old Apr 17, 2003 | 11:10 AM
vw-honda-hatches's Avatar
Default Procedures to replace piston rings.........
I already have the head off.
Got the correct tools.
Do i need to replace the bearings?
Do i need to replace the rod bolts.
This is a LS integra 1997 with 65k miles.
Thanks
Old Apr 17, 2003 | 11:48 AM
94CivicSi's Avatar
Default Re: Procedures to replace piston rings......... (vw-honda-hatches)
You need to visually inspect and plastiguage the bearings to determine whether they need to be replaced or not. With only 65K, I doubt it.
Check piston ring end gap by pulling the rings off, putting them in the cylinder one at a time, pushing them down to about 15-20mm from the bottom of the bore using the piston and measure the ring gap.
Why do you suspect such a young motor might need rings and/or bearings?
Old Apr 17, 2003 | 12:37 PM
Default Re: Procedures to replace piston rings......... (PIMPASSBEOTCH)
turbo'd vehicle..............fuel washboarded rings
not positive though
Old Apr 20, 2003 | 12:07 AM
LowAcura's Avatar
I need to change my rings too!
I have 66k miles on my car, already bruned a valve, burns oil like crazy. fixed the head, and still burning alot of oil. so now im going to buy new rings.
do we have to take part the crank to take out the pistons or is there a way to just take out the pistons without doign all this torturous work??
and, for stock motors, do we bu ythe standard rings? of course right?
i found a whole set of pisotn rings for 42 bucks. and they are a reputable place so i know they are good.
help me, help me please!
My compression is 195 for pistons 1-3 and piston 4 is 210. I didnt do a leak down test. but i was told it could be my blow by rings.???
Old Apr 20, 2003 | 12:42 AM
torr's Avatar
Default Re: (LowAcura)
i would leave the rod bearings alone and the rod bolts. since you've got the head off already. undo all your rods from the crank and then push up the piston and rods up threw the cylinder. that's it, if you run into any problems, be creative with it.
PINKFIFFTY
Jan 25, 2015 07:01 PM
Christopherian1982
10
Jan 22, 2009 11:00 PM
4EN[sic]
Aug 9, 2007 04:19 AM
carbonfib
May 15, 2007 05:59 PM
