How can i tell if the ecu im buying is chipped?
Re: (m3dia_lab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3dia_lab »</TD></TR><TR><TD CLASS="quote">what were u expecting</TD></TR></TABLE>
a scribble written with a permanent marker saying "chipped"
Re: (trooper0641)
If there is a 28 pin chip/soket soldered into that white rectangle area then somebody has been fooling around with the ECU - it's really that simple. as soon as you jumper J1 (purple) then your no longer using the stock maps and your engine is controlled by the 'chip' i the white area..
easy.
easy.
Re: How can i tell if the ecu im buying is chipped? (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">rough pics, but show you
so all i have to do is open the ecu up and check to see if i see a chip that is filled in on the right hand bottom side?
Re: How can i tell if the ecu im buying is chipped? (trooper0641)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">so all i have to do is open the ecu up and check to see if i see a chip that is filled in on the right hand bottom side?</TD></TR></TABLE>
yup, if there is no chip or socket then it has never been touched... you see a bunch of points filled in with solder if it is stock.
