Over heat problem
Old 09-30-2002, 09:56 AM
JDM EX's Avatar
Default Over heat problem
I have a 98 civic and it has Greddy Turbo Kit.. It run great and the problem is the radiator overheat.. I double check the radiator fluid and it is full.. I dont know what cause it over heat... I think it is thermostat.. Do u think thermostat is the problem.. LEt me know and how difficult to install it.. Thanks for help..
Old 09-30-2002, 09:58 AM
-Whitey-'s Avatar
Default Re: Over heat problem (JDM EX)
could be the thermostat or fan switch?
either of them are cheap and easy to install
plus they are both regular manitence so i would just change them
mugen fan switch/mugen rad cap/spoon thermostat
Old 09-30-2002, 10:10 AM
JDM EX's Avatar
Default Re: Over heat problem (one_honda)
THanks bro.. I barely have time to check what's wrong with my Civic.. I go college in out of town and I came home on weekend.. If the fan switch is not on, how can I turn it on.. Is it the fuse, or wire... Let me know and thanks for helping me...
Old 09-30-2002, 11:39 AM
Solbros Owns Me
Evs-One's Avatar
how high is it overheating?? Turn on your car, and wait about 10 minutes and see if the fan turns on. You can check the fan motor by connecting wire from the battery to the terminals on the fan switch. Check the relay fuse also. It could be the t stat, but usually doesn't go out that quick...could be your head gasket too- don't wanna make you worry. Is your overflow tank puking out???
Old 10-01-2002, 10:03 AM
JDM EX's Avatar
Default Re: Over heat problem (Emerica)
Thanks for reply.. Im not sure the headgasket has a problem.. If the headgasket have problem, they suppose to show the color of the smoke coming out of exhaust right... Im going to check the radiator fan to see if it on and if not, maybe I will check the fuse too.. Thanks for helping me out...
Pamc
03-13-2019 05:44 PM
zacheryleatherw
06-27-2011 02:52 PM
manny81
04-22-2007 12:23 PM
Donhonda84
04-04-2007 08:36 PM
jbscivichb92
11-15-2004 07:22 PM
Quick Reply: Over heat problem
