Oil Change options
Oil Change options
I'm due to have to change my oil at the end of next month and have some questions. I recently discovered handa-accessories which is near me so i can order online and pick it up. I have been using mobil one high mileage and purolator one filters. My question is should i stay with mobil one and purolator or switch to honda filters and oil, my cars a 97 civic dx if that's any concern. Thanks
Re: Oil Change options
honda doesn't formulate its own oil....or make its own filters. They source them out, and throw their sticker on it.
Or in other words, oil is oil....a filter is a filter *to an extent*
Id say use whatever is the better deal. If you want to get into the nitty gritty go over to bobistheoilguy.com where they have comparisons and tests. For most though if your vehicle is in good shape, as long as your regularly maint your vehicle, oil is oil.
oil is not just oil
and a filter is not just a filter
i use mobile synthetic
and for filters i use the purolator its a good one
For a stock motor, I run the recommended weight of whatever is cheap, but still a good brand. For filters, I usually go with Purolator PureONE unless I feel like spending more than $10.
Good info on oil: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/motor-oil-everything-you-wanted-know-more-1534856/
In-depth analysis of filters: http://www.300cforums.com/forums/gen...dissected.html
To answer your original question, you will be great with Mobil One oil and Purolator filters.
