oil filters for synthetic oil
Old 06-25-2006, 11:14 PM
floatfisher's Avatar
Default oil filters for synthetic oil
i did a lot of reading on oil but couldnt find the answer to my question. Anyway, can normal honda filters be used with synthetic oils??? I might be changing to redline oil and i wasnt sure if the normal honda filter will be ok for this application. If not what oil filters you guys running with redline???
Thanks
Old 06-26-2006, 07:24 AM
98 ITR's Avatar
Yes, the normal Honda filter can be used with synthetic oil.
Old 06-26-2006, 07:50 AM
Dave_B's Avatar
May I recommend the S2k filter.
Old 06-26-2006, 07:58 AM
Jon D's Avatar
Default Re: oil filters for synthetic oil (floatfisher)
HAMP
Old 06-26-2006, 10:34 AM
H-T Order of Merit
nsxtasy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floatfisher &raquo;</TD></TR><TR><TD CLASS="quote">can normal honda filters be used with synthetic oils??? I might be changing to redline oil and i wasnt sure if the normal honda filter will be ok for this application. If not what oil filters you guys running with redline???</TD></TR></TABLE>
Yes, you can use normal Honda filters with synthetic oil, including Mobil 1, Redline, etc.
Old 06-26-2006, 03:38 PM
projectTeG's Avatar
ive jest recently started using the napa gold filter and im really impressed with it...it raised my oil pressure and is a tad bit larger that my PureOne filter
Old 06-26-2006, 06:12 PM
1GreyTeg's Avatar
Let me ask you since several others have already stated that they can, Why you think an OEM filter might not work?
If it has similar to the same properties as dino oil why do you think it wouldn't work with said filter?
Old 06-26-2006, 08:07 PM
Circuit Star-29's Avatar
Default Re: oil filters for synthetic oil (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">May I recommend the S2k filter.</TD></TR></TABLE>
Ill second that...
Old 06-26-2006, 08:13 PM
p nut's Avatar
Just get the OEM.
Old 06-26-2006, 10:44 PM
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">Just get the OEM.</TD></TR></TABLE>
Not the small one though...made by Fram. Get the S2k...still made by Toyo Roki or whatever it is...
Old 06-26-2006, 10:50 PM
itr1244's Avatar
Default Re: (Circuit Star-29)
i know fram or whatever makes "synthetic" oil filter. i tired once but didnt get it again
it's too expensive
Old 06-27-2006, 09:07 PM
uNF$@#!'s Avatar
Default Re: (Dave_B)
the 9 dollar s2k filter?
NO
Old 06-27-2006, 09:10 PM
Default Re: (uNF$@#!)
COnsider this...
Although a small filter helps to regulate pressure more effectively, an s2k filter was designed with the capacity to allow higher rpms with out the by-pass opening...Plus, for those of us who have higher rev capacity, this filter was designed with 9k rpms in mind... That means a whole lot to me.
If you would like dirty oil flowing through your motor, by all means, save your self a few bucks. For me, I feel that the added benefit of a filter actually doing its job is worth many more dollahs than that of the s2k filters' pricing.
Old 06-28-2006, 03:13 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uNF$@#! &raquo;</TD></TR><TR><TD CLASS="quote">
NO </TD></TR></TABLE>
$9 ??? No way, I get em for like 4.50 or so.
&lt;---- has the inside hookup.
Old 06-28-2006, 05:03 PM
^^ hahaa..exactly..I get mine for 6 bucks...
shadow4510
02-15-2012 07:16 AM
mangofresh
Honda Fit
19
04-05-2010 01:03 PM
Kingsta18
Honda S2000
21
07-11-2006 04:12 PM
yoshi234
09-28-2001 06:23 AM
IS3M-T8
06-28-2001 10:11 AM
Quick Reply: oil filters for synthetic oil
