b16a2 into eg question
ok im gonna pick up a b16 swap for my 94 eg hatch shell and i had a quick question, since its an obd2 motor and the car is obd1 will everything just plug and play? or do i need a jumper harness? just wanna make sure so i dont run into problems.
Re: b16a2 into eg question
u could get a gsr engine harness that is obd2 and it will be plug and play. and wire vtec from the shock tower harness to the ecu.
or wire the stock eg harness so its obd2. and wire vtec
u will need a obd1 b16 ecu or and ecu with b16 specs.
no jumper harness that's if u were to use the and obd1 ecu in an obd0 or obd2 car.
so to make the motor obd1 i can use the obd2 wiring harness with a obd1 ecu? i didnt plan on messin with the obd2 b16 but im getting it pretty cheap so i guess its a chance to learn something new.
trevek10
09-17-2009 05:28 PM
2wheelhunter
06-04-2007 04:18 PM
screen_name
04-22-2006 06:56 PM
