obd1 emissions
obd1 emissions
I have a 99ex with the stock obd2 system. I am thinking of switching to obd1 so I can do some tuning. When it is time for me to take emissions, will I run into any problems because they are going to test for the obd2 system? Any help will be appreciated. Thanx
Re: obd1 emissions (zerokool1128)
what if I get the obd2-obd1 conversion harness and just get an obd1 ecu and distributor. When emissions comes around, I could just remove the obd1 dist. and ecu and be good right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerokool1128 »</TD></TR><TR><TD CLASS="quote">what if I get the obd2-obd1 conversion harness and just get an obd1 ecu and distributor. When emissions comes around, I could just remove the obd1 dist. and ecu and be good right?</TD></TR></TABLE>
If you pass right now, then yes, you could just make your car how it is now just to smog it, and you will pass.
