Not the right engine in my CX
Old 04-06-2005, 02:48 PM
colslaw87's Avatar
Default Not the right engine in my CX
And anyone that knows anything about civics? My friend has a 95 civic cx hatchback which is only supposed to have 70 hp. He looked at the engine code on the engine and it was a D15b, which is not the cx engine (weird). And his valve cover says 16 valve, which shouldn't be right either, it should be 8 valve. He also has Mitsubishi belts. And he bought it stock with no upgrades.
Old 04-06-2005, 02:55 PM
komat's Avatar
Default Re: Not the right engine in my CX (colslaw87)
he has the jdm d15b VTEC motor 130Hp
the guy probably swaped it
common thing
Old 04-06-2005, 03:07 PM
jlacoy82's Avatar
Tell you're friend hes lucky.
Old 04-06-2005, 03:11 PM
Risky Business
BauleyCivic's Avatar
Default Re: Not the right engine in my CX (jlacoy82)
If it says "16 valve" on the valve cover it is probably a d15B7...
Old 04-06-2005, 03:14 PM
civiccpedx's Avatar
Default Re: Not the right engine in my CX (BauleyCivic)
yeh the d15b doesn't say 16 valve on the cover, but the d15b7 does, check the engine code again
Old 04-06-2005, 03:23 PM
blaster834's Avatar
yea the misubitchy belt doesnt mean anything... but yea its probaly from a DX
Old 04-06-2005, 03:25 PM
untitledsn41's Avatar
Default Re: (blaster834)
or maybe it is a DX... does it have side moldings?
Old 04-06-2005, 04:11 PM
Bond's Avatar
Default Re: (untitledsn41)
D15b7 will have 16valve on the cover. Rub a little harder after the b and a 7 should appear. Sounds like a stock DX motor to me. As far as the Mitsubishi belts go, I have them on my stock Dx too. Nothing special. Pretty sure they all came with them because I still have stock belts on me Dx (only has 82Km). Check to see if there is a vtec solinoid and wiring.
Old 04-06-2005, 04:25 PM
CXified's Avatar
I'm pretty sure there is a non-VTEC D15B, it is similar to the D15B7, either that or it could be a D15B block that just has a B7 head on it, probably from someone snagging the VTEC head and exchanging that for their head.
Old 04-06-2005, 07:32 PM
gamby's Avatar
Regardless of which D15B it is, he's a lucky ****. He's got an extra 30 HP, which is pretty nice in a car that weighs that little.
I know my cx would benefit greatly from a free extra 30 hp
Old 04-07-2005, 05:19 PM
colslaw87's Avatar
Default Re: Not the right engine in my CX (gamby)
yeah it is the D15b7, and he lucky as ****, DX engine in a CX. He also got it from Canada.
Old 04-07-2005, 05:26 PM
notstock93's Avatar
Are you guys sure the belts dont say "MitsubOshi"?
Those were OEM belts when I used to work for Honda, I remember something about those belt names. That may explain some things.
If they really do say Mitsubishi....weird.
Old 04-07-2005, 05:28 PM
MagnaniEG6's Avatar
Same thing happen to me I have 95 cx with a dx motor pretty quick if I might add. But weird!
Old 04-07-2005, 05:41 PM
snowman0520's Avatar
canadien cx have us dx specs(engine etc.). so its nothing special
Old 04-07-2005, 06:01 PM
TheNasty0ne's Avatar
Default Re: Not the right engine in my CX (MagnaniEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagnaniEG6 &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happen to me I have 95 cx with a dx motor pretty quick if I might add. But weird!
Motor looks pretty crusty
Old 04-07-2005, 06:23 PM
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
Default Re: Not the right engine in my CX (OoBryan)
the cx motor's intake manny would be small
and each time you make a turn you would need to downshift
the gears are also pathetic
Old 04-07-2005, 06:48 PM
98EJ's Avatar
Default Re: (snowman0520)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowman0520 &raquo;</TD></TR><TR><TD CLASS="quote">canadien cx have us dx specs(engine etc.). so its nothing special</TD></TR></TABLE>
yes this is true, all Canadian cx's came with the D15B7
Old 04-07-2005, 07:23 PM
B16aDasher's Avatar
Default Re: (98EJ)
humm my cx is from canada. Maybe it had
a b7 in it
Old 04-07-2005, 07:39 PM
BlueIntegraBoy's Avatar
Default Re: (B16aDasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher &raquo;</TD></TR><TR><TD CLASS="quote">humm my cx is from canada. Maybe it had
a b7 in it </TD></TR></TABLE>
Technically all North American EG/EK hatches come from Canada.
Old 04-07-2005, 07:45 PM
EG-CX's Avatar
Yep, D15B7 were stock in Canada. The one in my 95 CX has over 432,xxxkm & still running strong! The timing belt was just done too, so I can still run it until I can afford a K20A2 swap.
Old 04-07-2005, 08:01 PM
4DRPIMPIN's Avatar
Edit: sorry double post.
Old 04-07-2005, 08:03 PM
4DRPIMPIN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Tell you're friend hes lucky. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by colslaw87 &raquo;</TD></TR><TR><TD CLASS="quote">yeah it is the D15b7, and he lucky as ****, DX engine in a CX. He also got it from Canada.</TD></TR></TABLE>
WtF? haha . Its a d15 for crying out loud. With these reactions you think he came across a k20 under the hood. oh well
Full Intensity
44
11-19-2004 01:46 PM
WarCivic
10
10-07-2004 03:51 PM
rjr162
04-20-2004 08:55 PM
thors_lx_grape
12-17-2002 03:13 PM
slo95cx
28
05-13-2002 01:27 PM
Quick Reply: Not the right engine in my CX
