Not the right engine in my CX
And anyone that knows anything about civics? My friend has a 95 civic cx hatchback which is only supposed to have 70 hp. He looked at the engine code on the engine and it was a D15b, which is not the cx engine (weird). And his valve cover says 16 valve, which shouldn't be right either, it should be 8 valve. He also has Mitsubishi belts. And he bought it stock with no upgrades.
Re: (untitledsn41)
D15b7 will have 16valve on the cover. Rub a little harder after the b and a 7 should appear. Sounds like a stock DX motor to me. As far as the Mitsubishi belts go, I have them on my stock Dx too. Nothing special. Pretty sure they all came with them because I still have stock belts on me Dx (only has 82Km). Check to see if there is a vtec solinoid and wiring.
I'm pretty sure there is a non-VTEC D15B, it is similar to the D15B7, either that or it could be a D15B block that just has a B7 head on it, probably from someone snagging the VTEC head and exchanging that for their head.
Re: Not the right engine in my CX (colslaw87)
Regardless of which D15B it is, he's a lucky ****. He's got an extra 30 HP, which is pretty nice in a car that weighs that little.
I know my cx would benefit greatly from a free extra 30 hp
Are you guys sure the belts dont say "MitsubOshi"?
Those were OEM belts when I used to work for Honda, I remember something about those belt names. That may explain some things.
If they really do say Mitsubishi....weird.
Re: Not the right engine in my CX (MagnaniEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagnaniEG6 »</TD></TR><TR><TD CLASS="quote">Same thing happen to me I have 95 cx with a dx motor pretty quick if I might add. But weird!
Motor looks pretty crusty
Location: With my POS D15B2, Whereever whenever, United States
Re: Not the right engine in my CX (OoBryan)
the cx motor's intake manny would be small
and each time you make a turn you would need to downshift
the gears are also pathetic
Re: (snowman0520)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowman0520 »</TD></TR><TR><TD CLASS="quote">canadien cx have us dx specs(engine etc.). so its nothing special</TD></TR></TABLE>
yes this is true, all Canadian cx's came with the D15B7
Re: (B16aDasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher »</TD></TR><TR><TD CLASS="quote">humm my cx is from canada. Maybe it had
a b7 in it </TD></TR></TABLE>
Technically all North American EG/EK hatches come from Canada.
Re: (B16aDasher)
Yep, D15B7 were stock in Canada. The one in my 95 CX has over 432,xxxkm & still running strong! The timing belt was just done too, so I can still run it until I can afford a K20A2 swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Tell you're friend hes lucky. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by colslaw87 »</TD></TR><TR><TD CLASS="quote">yeah it is the D15b7, and he lucky as ****, DX engine in a CX. He also got it from Canada.</TD></TR></TABLE>
WtF? haha . Its a d15 for crying out loud. With these reactions you think he came across a k20 under the hood. oh well
slo95cx
28
05-13-2002 01:27 PM
