New headgasket wont start help pls
I just put a new headgasket in my 94 d15b7 motor now it won't start has head resurfaced and tested I have spark and fuel checked compression it reads 90 130 130 130 could it be bad valve seals or timing? Any help is needed thanks
Re: New headgasket wont start help pls
You have one low cylinder.
Is spark bright white at all 4 plugs?
Is the mechanical timing dead on?
Is the plug wire firing order correct?
i know the bottom mark is good dont know about cam tho im missing the plastic cover with the timing mark so I just eyeballed it
I got the cover with the timing mark and lined it up but it still won't start compression went up 130 160 160 160
