obd1 motor to obd 2 crank position sensor need help fast
Old Jun 3, 2012 | 03:00 PM
boobstedminime's Avatar
Default obd1 motor to obd 2 crank position sensor need help fast
i just did a motor swap a d15z1 with a z6 head im using the obd 2 harness with an obd1 conversion harness i keep throughing a ckp cel can i just use the 1.6 obd2 oil pump and crank gear neeed help fast
Old Jun 3, 2012 | 07:33 PM
civickiller's Avatar
Default Re: obd1 motor to obd 2 crank position sensor need help fast
its the distributor unless im misunderstanding what youre saying
Old Jun 3, 2012 | 10:19 PM
HondaPartsHero's Avatar
Technical Hero
Need more info on the car and CKP sensor is inside the distributor not by the crank that's the CKF.
Old Jun 4, 2012 | 07:01 AM
Every were I'm reading I'm hearing that on an obd2 harness th cfs and cps are integrated I took the guts out of the obd2 dizzy cause they are the same and put it in an obd1 housing I under stand hat wither obd1 it picks up the signal for the cps from dizzy i might need a cps or cfs bypass
Old Jun 4, 2012 | 03:49 PM
no bypass needed, all wires and sensors that are needed are already inside dizzy and wire harness
my first car was a 91 civic, i did a dpfi-mpfi, obd0-obd1, p06 ecu tuned, and a obd2 '96 ls swap soldering a obd2 dizzy plug and obd2 injector plugs on chassis harness. it worked fine no codes. later did a lsvtec so i bought a 96 gsr dizzy it on there no codes
oh this was all on the stock obd0 harness
only wires added was for dpfi-mpfi swap
Old Jun 5, 2012 | 03:45 AM
Do u have a pin out for the obd1 to obd2 dizzy plug
Old Jun 5, 2012 | 10:36 AM
sorry i dont
Old Jun 6, 2012 | 09:04 AM
dpetro1's Avatar
please post the cel code number you are getting. i assume its code 9? and obd1 ecu would not look for the CKF sensor so it would have to be an issue with the dizzy
here is a dizzy pinout
sikcrx80
May 1, 2023 05:16 PM
jdmcivic1999
Jun 3, 2009 10:44 AM
B16CRXT
Mar 5, 2008 09:40 AM
EJgsr
Oct 19, 2006 07:54 AM
