--Need help with swap-
Old 02-05-2005, 07:05 AM
0 0 0's Avatar
Default --Need help with swap-
i have a 96 civic dx hatch..
i swaped a b20b with gsr tranny into it everything is hooked up no leaks yet...i cant get it to run
so far it sounds like it wants to turn over but it isnt.FUEL is on the plugs and im getting spark...
im thinking i have the timing wrong or maybe the spark plug wires wrong..any thoughts or experience of this..
im running an obd2-1 ecu jumper with an obd1 ls ecu
any questions or things u need to know just ask....TIA
Old 02-05-2005, 07:11 AM
jlacoy82's Avatar
Default Re: --Need help with swap- (vxHATCHATTACK)
Pull your distributor off, turn the crank pulley/cam 180 degrees and reinstall the distributor. Hopefully its just a matter of your timing being 180 degrees off.
Good luck!
Old 02-05-2005, 07:33 AM
Mr. Badwrench
boostedcivicsir's Avatar
put new plugs in it, make sure the firing order is correct, crank it while you floorboard the gas and fire it up.
Old 02-05-2005, 08:51 AM
0 0 0's Avatar
Default Re: --Need help with swap- (boostedcivicsir)
has new plugs(ngk)...not sure of the firing order i have a book but it is telling me that the motor is spinning the opposite way it actually is..ive cranked it while full throttle also...im about to go try and see if its 180 out
Old 02-05-2005, 09:07 AM
jlacoy82's Avatar
Firing order is 1342, looking at the dizzy cap from the passengers fender its:
13
24
#1 cylinder being farthest to the right side of the engine. Good luck sir!
Old 02-05-2005, 05:45 PM
0 0 0's Avatar
Default Re: --Need help with swap- (jlacoy82)
okay... i changed the plugs wires and timed agian and its starts.
it idles at about 2k it backfires thru the intake and the exhaust.
and when giving throttle it boggs.... i tried to switch the map and tps sensor and that didnt fix it...
and with the iacv and tps sensors unplugged it runs the same
Old 02-05-2005, 06:16 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Pull your distributor off, turn the crank pulley/cam 180 degrees and reinstall the distributor. Hopefully its just a matter of your timing being 180 degrees off.
Good luck!</TD></TR></TABLE>
B series distributors are keyed, you cannot physically install it 180 degrees off without a large hammer.
Old 02-05-2005, 08:12 PM
Honda Type R's Avatar
Default Re: --Need help with swap- (Kamin)
we got it to idle lower by forcing the throttle body closed further. it idles really rough and sounds like it missing.
Old 02-05-2005, 08:48 PM
SuperSteve737's Avatar
let it run for a while, then try and do a compression test. it will let you know if it is indeed missing. compression testers only cost like $20-30 from autozone or sears or whatever.
Old 02-05-2005, 09:31 PM
hatchbackhonda's Avatar
Default Re: (SuperSteve737)
did you mess with the timing at all before u swapped the car i have ran into instances that match your description and it was the timing! check the cam gears and belt and make sure u are not off a tooth
Old 02-07-2005, 08:03 AM
0 0 0's Avatar
Default Re: (hatchbackhonda)
the plug wires were in the wrong order still, and the tps was on wrong and throwing a code i reset the computer and now all i have is an idle air control valve code and i have tried 1 i know for a fact works but other that that it runs good just wont idle when cold(iacv)
so my new problem is whats wrong with the iacv? its plugged in and worked on another car?
im at a loss for this one
Sturg
10-27-2009 12:04 AM
rayzian
13
12-18-2006 03:35 PM
0 0 0
02-05-2005 07:45 PM
decypha
09-04-2002 05:51 AM
Quick Reply: --Need help with swap-
