distributor issue
Old Oct 19, 2009 | 04:05 PM
Sturg's Avatar
Default distributor issue
had to get a new distributor, put it on, car wont start
help please?
Old Oct 19, 2009 | 08:17 PM
ILS_09's Avatar
Default Re: distributor issue
did u mark the top bolt(nut) with a market or some short because if you don't, there is a good chance you messed up timming or firing order or what ever it is called.
Old Oct 19, 2009 | 11:01 PM
ILS_09's Avatar
srry for spelling i meant "marker"
Old Oct 20, 2009 | 07:17 AM
mouab18c1's Avatar
did you put the firing order of the spark plug wires in the correct order? did you check for fuel? spark?
Old Oct 21, 2009 | 06:09 PM
Sturg's Avatar
the plugs are getting spark, i can smell fuel when i try to start it, how can i make sure its getting to it though? and i did put the firing order of the plugs right... everything is hooked up how its supposed to be and the distributor only goes in one way, so there is no chance i messed up timing, i've asked two mechanics and they said i didn't, for some reason it just wont turn over, like it will crank but sit there and not do a damn thing..
Old Oct 21, 2009 | 06:27 PM
Sturg's Avatar
and if i somehow did mess up the timing, how would i fix it, i've tried playing w/ it, like moving the dizzy and try cranking it but nothing works? should i check spark in all four plugs, i checked the #4 plug when i did check it.
i miss my car haha, and i got new rims to put on and i want it to be all fixed for the weekend lol.
Old Oct 21, 2009 | 06:34 PM
jdmtegrunner's Avatar
When you replace the the distributor you make sure its on cylinder #1 other wise you will screw the timing. I had the same issue I messed with it by turning it 180 deg. So I messed the timing because I turned back the way it was and it didnt start. So I took the valve cover off and yeah the cam gears were set off. I think its the timing. Fix it then before you put in the distributor make sure its on cylinder #1. Then you should be all set. that is if you are getting fuel and spark.
Old Oct 21, 2009 | 07:15 PM
Sturg's Avatar
so can you explain how to fix the timing please, ha im new to this stuff. sorry.
Old Oct 21, 2009 | 07:23 PM
(TRY AT YOUR OWN RISK IM NOT RESPONSIBLE FOR ANY DAMAGES)
Look Ive been working on hondas for 2 months ever in my life. Ok heres how to do the timing you have to take the driver side rim off to be able to access the pulley. Ok then take the valve cover off, loosen the timing belt there should de a bolt right above the pulley, Loosen it do not take it off.
Ok take the belt off the cam gears. Then you have to put cylinder #1 at TDC( cylinder 1 is the one farthest from the distributor) by doing that you take all the spark plug wires off to avoid accidental start of the motor.
Take the #1 spark plug out then take a flash light and you have someone crank the motor but a second at a time till you see the cylinder head at the top.
Then you take a rachet and turn the motor about 6 degrees before it reaches the top top.
Ok cylinders are at correct timing.
Then for the cam timing. look at the cam gears the should have 1 arrow on each that (says up in the arrow). turn the cams till both arrows are pointing up.
Then put the belt back in position and tighten the belt till the tension is good on equal parts of the belt.
Then put the valve cover back on and make sure everything is connected right like the distributor.
Ok before you start up you should open the distributor cap and it should be at cylinder #1.
ok tighten everything the distributor, plugs, valve cover, everything you took off.
(SOMEONE CORRECT ME IF IM WRONG PLEASE)
Then start the engine. Hope it works. Or if you think you cant do it find a mecanic and have em do it.
Old Oct 21, 2009 | 07:40 PM
Sturg's Avatar
well thats great haha, sounds complicated.
thanks for the info though man, i appreciate it.
Old Oct 21, 2009 | 07:52 PM
Well if your low on cash like I was just do some research and you'll be able to do it. Or just get a mecanic they should be able to do it in about half an hour to an hour or so. And my guess as for fixing timing they should charge no more than 50 bucks. Hope it solves your issue.
Old Oct 22, 2009 | 03:18 PM
Sturg's Avatar
like if we were to take the #1 spark plug out and used a flashlight to see down inside and cranked it until it was at tdc would that work?
Old Oct 22, 2009 | 03:29 PM
Sturg's Avatar
and i dont know how i could have messed up the timing... the distributor only goes in one certain way?
Old Oct 22, 2009 | 04:22 PM
gilcontr's Avatar
you must have screwed up your spark plug order. i can't see how you could have messed up your timing. make sure that none of the spades on the distributor connections are backed out from the socket.
Old Oct 22, 2009 | 04:29 PM
Sturg's Avatar
my spark plug order is right. should i just go get a new cap and rotor and see if that does it?
Old Oct 22, 2009 | 07:51 PM
Yes but you have to crank the motor a lil bit to the front by putting the ratchet on the pulley and you crank it a lil bit forward. That would be it for the crank. Its good if you put a crean wire just to check the position of the piston. Then just line up the cam gears with the arrows pointing to the top. Place the belt back on and assemble everything you took apart. And start it up.
Old Oct 22, 2009 | 07:56 PM
I didnt know how mine got screwed until I took off the valve cover my cams werent lined up thats how I knew but still dont know how it happened. Anyway I got it up and running. Its a 92 gs-r the aztec green one.
Old Oct 23, 2009 | 08:09 AM
Sturg's Avatar
do you live in ohio???
Old Oct 23, 2009 | 10:09 AM
mouab18c1's Avatar
so is your old distributor dead? try using your old one
Old Oct 24, 2009 | 01:51 AM
Sturg's Avatar
my old one is god knows where.... autozone took it :/
Old Oct 24, 2009 | 03:36 PM
Naw man sorry I live in SW US.
Old Oct 25, 2009 | 01:44 PM
Sturg's Avatar
oh, i thought i saw your car around here.
Old Oct 25, 2009 | 04:16 PM
xero_xero's Avatar
your distributor may be off 180 degrees (yes it is easy to do, even though some say it is impossible, seen it done it). remove it, rotate it 180 around and reinstall it. if you are still having a problem, check for spark in each plug, then check each plug.
Old Oct 25, 2009 | 05:44 PM
Rajin's Avatar
If its trying to crank, and spark is hitting, adjust the position of the distributor.
You live in Ohio. I can come help, its over 8 hours so I'd need some food for it.
That is all.
Old Oct 27, 2009 | 12:04 AM
Sturg's Avatar
are you sure because it doesn't wanna go in at all when i turn it 180 and i dont wanna cram it in there and mess something up....
and haha i can get a **** load of food for ya
Tommy818
28
Oct 22, 2012 10:00 AM
egtony
10
Sep 4, 2009 01:44 PM
ILOVEGIRLS
Apr 19, 2006 07:52 PM
Ri5e
Apr 4, 2002 12:20 PM
